Zyxel NWA130BE – Power Options (PoE, DC Jack and USB Type-C)
The Zyxel NWA130BE can be powered in different ways depending on the hardware version of the device.
All NWA130BE models support Power over Ethernet (PoE). In addition, some models have a 12 V DC barrel power connector, while newer models use USB Type-C with USB Power Delivery (USB PD).
This article explains which power options are supported and how to identify the correct power input for your device.
Supported Power Options
Power OptionRequirementSupported Devices
PoEIEEE 802.3at, power draw up to 24 WAll NWA130BE models
DC barrel jack12 V DC, 2 AEarlier models
USB Type-CUSB PD, 15 V DC, 2 AModels released after June 2025
Hardware Version and Serial Number
There are two hardware versions of the NWA130BE regarding the DC power connector.
Models released after June 2025 are equipped with a USB Type-C power port instead of the older round DC barrel jack.
The USB Type-C version starts from serial number: S250Y13073732
Serial NumberPower Connector
Earlier than S250Y1307373212 V DC barrel jack
S250Y13073732 and laterUSB Type-C, USB PD
So, if the serial number of the device is S250Y13073732 or higher, the device uses USB Type-C for external DC power.
If the serial number is lower, the device uses the older 12 V DC barrel jack.
Power over Ethernet
The recommended way to power the NWA130BE is PoE, because power and network connection are provided through the same Ethernet cable.
Supported PoE modes:
PoE StandardSupport Status
IEEE 802.3afNo wireless operation
IEEE 802.3atSupported / Unrestricted
IEEE 802.3btSupported / Unrestricted
  • The required PoE standard is: IEEE 802.3at
  • Power draw: 24 W
Models with DC Barrel Jack
For older models with a round DC power connector, use a power adapter with:
  • 12 V DC
  • 2 A
  • 24 W
Models with USB Type-C
For newer models with USB Type-C, use a USB-C power adapter that supports:
  • USB Power Delivery
  • 15 V DC
  • 2 A
  • 30 W or higher recommended
Important: A normal USB-C charger is not automatically compatible. The charger must support the 15 V USB PD power profile. Chargers that only provide 5 V, 9 V, or other profiles may not power the access point.
If a multi-port USB-C charger is used, make sure the port connected to the NWA130BE can still provide 15 V / 2 A when other devices are connected.
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
