How to Collect Diagnostic Information from a Zyxel Nebula Access Point via GUI
Zyxel Nebula Access Points include a built-in diagnostic utility that allows administrators to generate support logs and troubleshooting files directly from the local Web GUI.
These diagnostic files are essential for analyzing:
  • AP offline issues
  • WiFi client disconnects
  • roaming problems
  • DHCP/DNS failures
  • cloud connectivity issues
  • wireless performance degradation
This article explains how to collect diagnostic information from a Zyxel Nebula AP using the local GUI interface before opening a support case with Zyxel Support.
Prerequisites
Before collecting diagnostics, ensure the following requirements are met:
  • The AP is powered on and connected to the network
  • Your PC is connected to the same subnet as the AP
  • You know the AP IP address
  • Administrator credentials are available
  • A web browser is installed
Note: Depending on the firmware version, the AP may display an HTTPS certificate warning because it uses a self-signed certificate.
Find the AP IP Address in Nebula
  • Log in to the Nebula Control Center.
  • Navigate to: Site-wide - Devices - Access points
Access the AP Local Web GUI
  1. Open a web browser.
  2. Enter the AP IP address using HTTPS:
Open the Diagnostics Menu
After successfully logging in to the AP local GUI:
  1. Navigate to: Maintenance → Diagnostics
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
