Zyxel NWA50BE PRO & NWA90BE PRO — Overview and Quick Setup
The Zyxel NWA-BE PRO series marks Zyxel’s entry into the WiFi 7 era, delivering blazing-fast wireless speeds, flexible deployment, and easy management. With two new models — NWA50BE PRO and NWA90BE PRO — Zyxel addresses both SoHo users and small-to-medium businesses (SMBs), providing an affordable yet powerful upgrade to the latest IEEE 802.11be (WiFi 7) standard.
Key Differences — NWA50BE PRO vs NWA90BE PRO
Feature NWA50BE PRO NWA90BE PRO
Security Encryption WPA/WPA2/WPA3 Personal only WEP + WPA/WPA2/WPA3 Personal & Enterprise
Authentication — IEEE 802.1X / RADIUS support
Captive Portal — ✔ Built-in Captive Portal (customizable guest login pages)
Both devices feature
WiFi Standard IEEE 802.11be/ax/ac/n/g/b/a IEEE 802.11be/ax/ac/n/g/b/a
Max Data Rate Up to 6.5 Gbps Up to 6.5 Gbps
Radio / Streams 2.4 GHz: 2×2:25/6 GHz: 2×2:2 2.4 GHz: 2×2:25/6 GHz: 2×2:2
Per-Band Speed 2.4 GHz: 688 Mbps5 GHz: 4324 Mbps6 GHz: 5764 Mbps 2.4 GHz: 688 Mbps5 GHz: 4324 Mbps6 GHz: 5764 Mbps
Smart Mesh (MLO) ✔ Dual-radio backhaul ✔ Dual-radio backhaul
Security WPA/WPA2/WPA3 Personal WEP, WPA/WPA2/WPA3 Personal & Enterprise
Captive Portal ✘ ✔
Management NebulaFlex (Standalone GUI / Cloud) NebulaFlex (Standalone GUI / Cloud)
LAN Port 1 × 1/2.5GbE 1 × 1/2.5GbE
Power Options 12V adapter / PoE (802.3at, 16W) 12V adapter / PoE (802.3at, 16W)
PoE Support 802.3at ✔ / 802.3bt ✔ 802.3at ✔ / 802.3bt ✔
Summary of Differences
  • NWA50BE PRO → best for home offices and small businesses: fast WiFi 7, simple management, basic security.
  • NWA90BE PRO → best for SMBs and public networks: same performance but adds enterprise authentication (802.1X / RADIUS), captive portal for guest WiFi, and extended encryption options (including WPA3-Enterprise).
Everything else — hardware, radios, CPU, Smart Mesh MLO, management options, size, power, etc. — is identical between the two models.
Quick Setup Guide
Mounting Options
  • Wall or ceiling mount (mounting plate and screws included).
  • Optional BAR ceiling clips accessory for suspended ceilings.
  • Compact design: 5.9 × 5.9 × 1.38 inches.
Power & Connectivity
  • Power options:
    • PoE (802.3at) injector/switch (recommended)
    • 12V DC adapter (included)
  • Connect the AP’s 2.5GbE LAN port to a router/switch.
  • Wait until the LED indicator turns solid green (ready state).
    (See diagrams in Quick Start Guide, pages 1–2).
Initial Configuration
Two management modes are available: How to Register an Zyxel AP to Nebula
🔹 Nebula Cloud Mode
  1. Download the Nebula Mobile App (iOS/Android).
  2. Add the device by scanning the QR code (on the unit or in QSG).
  3. The AP auto-registers to Nebula Cloud, accessible from anywhere.
Option 1: Registration with the App Option 2: Registration with the Web
🔹 Standalone Mode
  1. Connect a client to the AP’s default SSID (printed on the device).
  2. Open http://setup.zyxel or the device’s IP address.
  3. Login with default credentials (found in QSG).
  4. Configure SSID, WPA/WPA3 passphrase, VLANs, and other options.
Logging into the Web GUI (Standalone Mode)
Both the NWA50BE PRO and NWA90BE PRO can be managed directly via their built-in Web GUI if you choose to run them in Standalone mode (without Nebula Cloud). This is useful for local configuration, lab testing, or environments where cloud management is not required.
For the NWA50BE PRO and NWA90BE PRO, the factory default password for the first login to the web interface (Standalone mode) is printed on the sticker located on the back of the device.
The next step will ask you to change the default password, this action is mandatory.
After changing the default password and re-logging in with the new credentials, the setup wizard will launch. For a basic configuration, you simply need to follow 5 straightforward steps.
Quick Setup Wizard — Step by Step
After changing the default admin password and logging in again, the Setup Wizard will guide you through 5 steps:
Step 1 – Time Settings
  • Select your Country and Time Zone.
  • Optionally enable Daylight Saving Time (DST) and configure start/end rules.
Step 2 – Uplink Connection
  • Choose how the AP gets its management IP:
    • Auto (DHCP) — recommended for most networks.
    • Static IP — if your network requires fixed addressing.
Step 3 – SSID and Security
  • Configure your wireless network name (SSID).
  • Select which bands to use (2.4 / 5 / 6 GHz).
  • Choose security type: WPA3-Personal (recommended), WPA2, or WPA3-Enterprise (on NWA90BE PRO).
  • Set your WiFi password (Pre-Shared Key).
Step 4 – Radio Settings
  • Adjust channel width and output power for each band:
    • 2.4 GHz: usually 20 MHz channels.
    • 5 GHz / 6 GHz: 80–160 MHz for maximum WiFi 7 performance.
  • Leave Channel Selection on Auto unless manual tuning is required.
Step 5 – Summary and Apply
  • Review all your settings: country, time zone, SSID, security, channels.
  • If everything looks correct, click Save.
  • The AP will apply the configuration and your WiFi network is ready.
Final Step — Configuration Applied
Once the wizard is completed:
  • The AP will use the new IP address (via DHCP or static, depending on your choice).
  • The default Zyxel SSID (Zyxel_xxxx) is removed.
  • Connect to the new SSID that you configured in Step 3 to start using your WiFi network.
Articles in this section
Was this article helpful?
4 out of 5 found this helpful
Share
