How to Register an Zyxel AP to Nebula
If you’re setting up a new Zyxel Access Point, one of the first steps is to register it with the Nebula Cloud Management platform. Registering your AP to Nebula allows you to centrally manage wireless networks, monitor performance, apply security policies, and enable advanced features like smart mesh and seamless roaming. In this guide, we’ll walk you step by step through the process of registering your AP using both the Nebula Mobile App and the Nebula Control Center (NCC) web portal, so you can quickly bring your device online and ready for cloud management.
Prepare Your Device
  • Ensure you have the MAC address and serial number (S/N) of the AP, which are printed on the device label.
  • If the device was previously used in Standalone mode, it’s recommended to back up its configuration in case you want to revert later.
Register via Nebula Mobile App (Quick with QR Code)
  1. Install the Nebula Mobile App (Google Play / App Store) and log in.
Select your Organization and Site, then go to Devices → Add Device (or press “+”).
Scan the QR code from your AP.
  • If the AP was already registered to another site/organization, select Register Device → Next.
Tap Register (X) Devices (X = number of devices scanned).
Tap Done to finish.
Tip: QR code scanning is the fastest way to add multiple devices at once.
Register via Nebula Web Portal (NCC)
Site-Wide Registration
  1. Log in at Nebula Control Center.
  2. Go to Devices → Add devices.
  3. Enter the MAC address and Serial Number of the AP.
  4. Click Finish.
Organization-Wide Registration (for multiple sites)
  1. Go to Organization-wide → License & Inventory → Devices → Add.
  2. Enter the MAC and S/N, then click Finish.
  3. To assign the AP to a site, select Action → Change Site Assignment, choose the site, and Save.
Managing Devices in Zyxel Nebula
One of the key advantages of Nebula Cloud Management is the flexibility it provides when managing devices across different sites within the same organization. After you register and assign your NWA50BE PRO or NWA90BE PRO to a site, you are not locked into that initial setup — you have several options to reorganize your deployment as your network evolves.
  • Device Registration: Once a device is onboarded into Nebula, it becomes registered under your organization, ensuring it remains associated with your account.
  • Removing from a Site: If you remove a device from a site, it does not disappear from your organization. Instead, it remains in your organization’s inventory, unassigned to any site. This allows you to reassign or redeploy the device at any time without repeating the registration process.
  • Moving Between Sites: You can easily move a registered device from one site to another within the same organization. This is especially useful if you are restructuring networks, relocating equipment, or scaling deployments across multiple offices or branches.
In short, Nebula offers centralized device ownership with flexible site assignment:
  • Devices are always tied to your organization.
  • They can be removed from or reassigned to sites as needed.
  • This approach simplifies asset management and ensures smooth transitions when expanding or reorganizing your network.
Articles in this section
Was this article helpful?
0 out of 1 found this helpful
Share
