Understanding the LED Indicators on Zyxel Access Points: A Guide for Users and Administrators
The LED indicators on Zyxel Access Points provide users and administrators with a quick and reliable way to understand device status, network connectivity, and activity. Zyxel applies a consistent LED design across its AP portfolio, making it easier to manage and troubleshoot mixed environments without confusion.
This guide covers LED behavior and Ethernet port indicators for the following Zyxel models: NWA130BE, WBE530, WBE630S, WBE510D, NWA210BE, NWA110BE, NWA110AX, NWA210AX, WAX510D, WAX610D, WAX630S, WAX300H LED, NWA220AX-6E, WAX620D-6E LED  and WAX650S. By learning how to interpret the LEDs on these devices—and how to use the LED suppression feature—you can ensure smoother operation and faster problem resolution.
NWA110AX, NWA210AX, WAX510D, WAX610D, WAX630S and WAX650S LEDWAX300H LED NWA220AX-6E, WAX620D-6E LED
WAX640S-6E, WBE660S LEDNWA130BE / WBE530 / WBE630S / WBE510D / NWA210BE / NWA110BE LED
Amber/Green LED
Q: Why is the LED blinking amber and green quickly (300 ms interval)?
A: The Zyxel Device is booting up.
Q: Why is the LED blinking amber and green slowly (1 second interval)?
A: The Zyxel Device is discovering the NCC (Nebula Control Center).
Q: Why does the LED blink amber/green 3 times and then turn solid green for 3 seconds?
A: The Zyxel Device is discovering an AC or is managed by NCC but fails to connect with NCC. It is retrying the connection.
Q: Why does the LED blink amber/green 2 times and then turn solid green for 3 seconds?
A: The Zyxel Device is managed by an AC, but the uplink is disconnected.
Green LED
Q: Why is the LED blinking green slowly (1s on / 1s off)?
A: The wireless module is disabled/failed, default WiFi settings are active, or the device is configured for NCC management but not yet registered.
(On some models WiFi is turned off automatically when powered by IEEE 802.3af PoE).
Q: Why is the LED solid green?
A: The Zyxel Device is ready for use, WiFi is active, and clients may be connected.
Amber LED
Q: Why is the LED solid amber?
A: The device is ready but in limited power mode. WiFi is active, and clients may connect, but some radios (depending on model) are disabled under IEEE 802.3af PoE.
Bright Blue LED
Q: Why is the LED solid bright blue?
A: WiFi is active, but no clients are connected, and the device is in full power mode.
White LED
Q: Why is the LED blinking white fast (100 ms per second)?
A: Locator LED is on — it will auto switch off after 1–60 minutes (default 10 minutes).
(Note: on some models, the LED may look light purple.)
Blue LED
Q: Why is the LED blinking blue slowly (1s on / 1s off)?
A: The Zyxel Device is performing a Channel Availability Check (CAC) with DFS to scan for radar signals.
Red LED
Q: Why is the LED solid red?
A: The Zyxel Device failed to boot or has a system failure.
Q: Why is the LED blinking red very fast (50 ms on / 50 ms off)?
A: The device is undergoing a firmware upgrade.
Q: Why does the LED blink red 3 times and then pause for 3 seconds?
A: The uplink of the Zyxel Device is disconnected.
COLORNAMESTATUSDESCRIPTION
Amber GreenBlinks between amber and green alternately (300 milliseconds interval).The Zyxel Device is booting up.
Amber GreenBlinks between amber and green alternately (1 second interval).The Zyxel Device is discovering the NCC.
Amber GreenBlinks between amber and green alternately 3 times and then turns solid green for 3 seconds.The Zyxel Device is discovering an AC, or is managed by NCC but fails to connect with NCC, and is reconnecting with the NCC.
Amber GreenBlinks between amber and green alternately 2 times and then turns solid green for 3 seconds.The Zyxel Device is managed by an AC but the uplink is disconnected.
GreenSlow Blinking (On for 1 second, Off for 1 second)The wireless module of the Zyxel Device is disabled or fails, the Zyxel Device is using default WiFi settings, or the Zyxel Device is configured to be managed by NCC but is not yet registered with the NCC. Note: WiFi networks on the WAX650S, NWA220AX-6E and WAX620D-6E are turned off automatically when it is connected to a device that supplies power using IEEE 802.3af PoE.
GreenSteady OnThe Zyxel Device is ready for use, the Zyxel Device’s wireless interface is activated, and/or WiFi clients are connected to the Zyxel Device in full power mode.
AmberSteady OnThe Zyxel Device is ready for use in limited power mode, the Zyxel Device’s wireless interface is activated, and/or WiFi clients are connected to the Zyxel Device. Note: WiFi networks on the WAX650S, NWA220AX-6E, WAX620D-6E and WAX640S-6E are turned off automatically when it is connected to a device that supplies power using IEEE 802.3af PoE. Not all models support limited power mode.
Bright BlueSteady OnThe Zyxel Device’s wireless interface is activated, but there are no WiFi clients connected when it is in full power mode.
WhiteSlow Blinking (On for 100 ms per second)Locator LED is on. It switches off automatically after the configured amount of time (1–60 min). Default duration is 10 minutes. Note: The color of the white LED may have slight differences (for example, very light purple) on different models.
BlueSlow Blinking (Blink for 1 second, Off for 1 second)The Zyxel Device is performing a Channel Availability Check (CAC) with Dynamic Frequency Selection (DFS) to monitor a channel for radar signals.
RedOnThe Zyxel Device failed to boot up or is experiencing system failure.
RedFast Blinking (On for 50 milliseconds, Off for 50 milliseconds)The Zyxel Device is undergoing firmware upgrade.
RedSlow Blinking (Blink for 3 times, Off for 3 seconds)The uplink of the Zyxel Device is disconnected.
Articles in this section
Was this article helpful?
4 out of 26 found this helpful
Share
