Zyxel IAP500BE — an industrial Wi-Fi 7 access point designed for Industry 4.0.
The Zyxel IAP500BE is an industrial-grade WiFi 7 (802.11be) access point engineered for demanding environments such as smart factories, warehouses, and Industry 4.0 deployments. Delivering multi-gigabit wireless speeds, ultra-low latency, and high reliability, it is designed to support mission-critical applications and real-time IoT systems. With a rugged fanless metal enclosure, extended operating temperature range, redundant power inputs, and flexible management via NebulaFlex Pro, the IAP500BE ensures stable, continuous wireless connectivity even in harsh industrial conditions.
Typical Use Cases
The Zyxel IAP500BE is ideal for environments where wireless connectivity is a critical part of operational continuity:
  • Manufacturing plants and production lines
  • Warehouses and logistics centers
  • Industry 4.0 and smart factory deployments
  • Industrial IoT (IIoT) sensors and controllers
  • Automated Guided Vehicles (AGVs)
  • Industrial cabinets and control rooms
  • Sites where cabling is impractical or costly
Package Contents
The standard package of the Zyxel IAP500BE includes:
  • Zyxel IAP500BE industrial access point
  • Two detachable 2.4 GHz / 5 GHz external antennas
  • DIN-rail mounting kit
  • Quick Installation Guide
Not Included in the Box:
  • DC power adapter
  • PoE injector
  • Alternative mounting accessories
  • Optional or specialized external antennas
Key Technical Specifications
Wireless Capabilities
  • Wireless standard: IEEE 802.11be (WiFi 7)
  • Backward compatibility: 802.11ax/ac/n/g/b/a
  • Frequency bands: 2.4 GHz and 5 GHz
  • MIMO: 2×2 MU-MIMO
  • Maximum data rates:
    • 2.4 GHz: up to 688 Mbps
    • 5 GHz: up to 4324 Mbps
  • Channel bandwidth: up to 240 MHz
Interfaces and Power
  • Ethernet: 1 × 1/2.5GbE LAN port
  • Power options:
    • PoE+ (IEEE 802.3at), power consumption up to 24 W
    • Redundant dual DC input (12–48 V) with reverse polarity protection
Industrial Design
  • Fanless metal enclosure
  • Operating temperature: –25°C to +65°C
  • Protection levels:
    • 6 kV lightning protection
    • 15 kV ESD protection
Key Features
WiFi 7 with Multi-Link Operation (MLO)
WiFi 7 introduces Multi-Link Operation (MLO), allowing devices to transmit and receive data across multiple frequency bands simultaneously. This significantly reduces latency, increases throughput, and improves reliability—critical for real-time industrial applications such as robotics, AGVs, and automation systems.
NebulaFlex Pro Management
With NebulaFlex Pro, the IAP500BE offers unmatched deployment flexibility:
  • Standalone mode for local management
  • On-premises controller-managed mode
  • Cloud-managed mode via Nebula Control Center (NCC)
Users can switch between modes without additional licensing costs, protecting long-term network investments.
Industrial-Grade Reliability
The IAP500BE is engineered to withstand harsh industrial conditions. Advanced RF filtering and interference mitigation ensure stable wireless performance even in environments with heavy machinery or dense 4G/5G signals. The fanless design enhances reliability while reducing maintenance requirements.
Smart Mesh and Wireless Bridge
  • Smart Mesh enables flexible wireless expansion in locations where cabling is unavailable
  • Wireless Bridge supports high-throughput point-to-point or point-to-multipoint connections between buildings or remote areas
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
