Zyxel Access Point Console - How to use the console port to Access Points
In this article, we will outline the appropriate console cable to use for connecting to an access point and provide step-by-step instructions for establishing a connection using PuTTY or Tera Term.
Suitable cable
The USB TTL cable is the cable with four pins including one pin with a triangle icon, please connect the USB TTL cable to AP by console cable’s pin with a triangle in the place of the AP console pin with a triangle icon (pin 1).
The USB TTL cable is as below image, please follow Zyxel’s console header pin definition:
  • Pin1  NA (leave empty )
  • Pin3 Green (TX)
  • Pin2 White (RX)
  • Pin4 Black (GND)
  •  Remember that don’t connect red color pin to Zyxel’s console pin.
Connection process
  • Connect the cable to your access point as described in the previous step.
  • Run the application (in our example, we use Tera Term)
  • Set "Serial" and choose the Port to which the cable is connected, as in the picture below.
  • In the Tera Term window that opens, click “Setup”
  • Select - Serial Port
  • In the “Speed” field, set 115200
  • Click  "New settings."
  • In the newly opened console window, you may need to press “Enter” to refresh the connection and see that the connection to the access point was successful.
  • Now, enter the username and password for your access point.
Instructions for CLI commands can be found on the download page for each device in our download database.
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
