Zyxel Access Point NWA210AX - PoE Injector
If you have a question about which PoE adapter is compatible with the NWA210AX access point, this article will tell you about it.
  • PoE (802.3) at power draw 19 W
  • DC input: 12 VDC 2A
It is recommended to use the Zyxel PoE 12-30W injector to power the NWA210AX.
RJ-45 (Data) Input1
RJ-45 (Data + Power) Output1
Data Rate100 Mbps and 1/2.5 Gbps
PoE StandardPoE, PoE+
Total PoE budget30 watts
What happens if I connect a PoE adapter with insufficient power to the NWA210AX?
The NWA210AX requires 802.3at power to operate in full power mode (4T4R antenna), if the power is insufficient, the AP will go into limited power mode and the antenna will be reduced to 1T2R as well as additional performance issues may occur. Therefore, we recommend providing sufficient power.
NWA210AX have POE-Out?
NWA210AX is not supported for PoE out.
Articles in this section
Was this article helpful?
1 out of 2 found this helpful
Share
