Including information about local users and AAA services (Radius, TACACS+) in the switch text-based configuration
For security purposes, the factory settings of the switches do not add settings for local user accounts (including SNMP) and settings for AAA servers (RADIUS, TACACS +)
In order to include information about users in the configuration file, you need to input a special command "display user". The syntax of the command also includes additional options.
"system" - display usernames, including system administrator account "admin" and "snmp" - display local snmp users. If no options are specified, then the "display users" command enables both functions.
GS2220(config)# display user ?
    <[system] [snmp]>         enable specific options
    <cr>                      enable all options
To display the parameters of AAA services in the configuration file, there is a command "display aaa" with add. "autentication", "authorization", "server" options. Without specifying parameters, all three are also included.
GS2220(config)# display aaa ?
    <[authentication][authorization][server]> enable specific options
Articles in this section
Was this article helpful?
0 out of 1 found this helpful
Share
