Zyxel Rack Mount Guide: 19" Installation Support for Switches and H Series Firewalls
This article explains how Zyxel firewalls and switches support installation in a standard 19-inch rack, with a focus on different models and form factors. It covers whether rack-mount brackets (“ears”) are included or required separately, how to identify rack-mountable devices, and how to confirm mounting options in official Zyxel documentation.
Note: This is general guidance. Always check the datasheet or installation guide for your exact model.
Key Concept
Standard 19" rack width:
  • 482.6 mm
If the device is smaller, rack ears are used to extend it to the full width.
How to Determine Mounting Type Based on device width
Device Width Mounting Type
< 250 mm Shelf / Desk only
250–430 mm Rack mount with extended ears
≥ 430 mm Standard 19" rack mount
Ear Size Calculation
Use this formula:
(482.6 mm − device width) / 2
This gives the approximate size of one rack ear.
Important Notes
  • Ear size is an estimate only
  • Hole positions and shape may vary
  • Always use original Zyxel rack kits when possible
Also, use universal mounts, but only after first checking for compatibility:  How to Find Zyxel Accessories and Replacements
Firewall
USG FLEX 500H / USG FLEX 700H
USG FLEX 200H / HP
Model Rack-mountable Rack kit rack 19 inch included Device dimensions (W × D × H, mm) Rack kit size per side (mm)
USG FLEX 50H / HP No No 216 × 143 × 33 Desktop device
USG FLEX 100H / HP No No 216 × 143 × 33 Desktop device
USG FLEX 200H / HP Yes Yes 272 × 187 × 36 ~105 mm
USG FLEX 500H Yes Yes 300 × 182 × 43.5 ~91 mm
USG FLEX 700H Yes Yes 430 × 250 × 43.5 ~26 mm
Switch
Zyxel switches can have two different mounting hole patterns. Both options are shown in the pictures with dimensions.
In the table below, you can find information about which switches can be rack-mounted and which cannot. It also shows device dimensions and mounting sizes.
Model Rack-mountable Rack kit rack 19 inch included Device dimensions (W×D×H,mm) 19" Rack kit size per side (mm)
GS1100-24ES Yes Yes 280 x 126 x 44 ~101.3 mm
GS1900-24E Yes Yes 267 x 162 x 42 ~107.8 mm
GS1915-24E Yes Yes 267 x 162 x 42 ~107.8 mm
GS1100-24E Yes Yes 267 x 162 x 42 ~107.8 mm
GS1350-12HP Yes Yes 267 x 162 x 44 ~107.8 mm
GS2220-10 Yes Yes 267 x 162 x 44 ~107.8 mm
GS2220-10HP Yes Yes 267 x 162 x 44 ~107.8 mm
GS1920-8HPV2 Yes No 267 x 162 x 44 ~107.8 mm
GS1900-24 Yes Yes 440 x 131 x 44 ~26 mm
GS1900-48 Yes Yes 440 x 200 x 44 ~26 mm
GS1920-48V2 Yes Yes 440 x 200 x 44.5 ~26 mm
GS2220-50 Yes Yes 440 x 200 x 44.5 ~26 mm
XGS1935-28 Yes Yes 440 x 270 x 43 ~26 mm
XGS1935-28HP Yes Yes 440 x 270 x 43 ~26 mm
XGS1935-52 Yes Yes 440 x 270 x 43 ~26 mm
XGS1935-52HP Yes Yes 440 x 270 x 43 ~26 mm
GS1920-24V2 Yes Yes 441 x 131 x 44 ~26 mm
GS2220-28 Yes Yes 441 x 131 x 44 ~26 mm
GS1350-26HP Yes Yes 441 x 270 x 44 ~26 mm
GS1920-24HPV2 Yes Yes 441 x 270 x 44 ~26 mm
GS1920-48HPV2 Yes Yes 441 x 270 x 44 ~26 mm
XGS1930-28 Yes Yes 441 x 270 x 44 ~26 mm
XGS1930-52 Yes Yes 441 x 270 x 44 ~26 mm
XMG1930-30 Yes Yes 441 x 270 x 44 ~26 mm
GS2220-28HP Yes Yes 441 x 270 x 44 ~26 mm
GS2220-50HP Yes Yes 441 x 270 x 44 ~26 mm
XGS2220-30 Yes Yes 441 x 270 x 44 ~26 mm
XGS2220-30F Yes Yes 441 x 270 x 44 ~26 mm
XGS2220-54 Yes Yes 441 x 270 x 44 ~26 mm
XGS1930-28HP Yes Yes 441 x 330 x 44 ~26 mm
XGS1930-52HP Yes Yes 441 x 330 x 44 ~26 mm
XMG1930-30HP Yes Yes 441 x 330 x 44 ~26 mm
XMG2230-28HP Yes Yes 441 x 330 x 44 ~26 mm
XMG2230-52HP Yes Yes 441 x 330 x 44 ~26 mm
XGS2220-30HP Yes Yes 441 x 330 x 44 ~26 mm
XGS2220-54HP Yes Yes 441 x 330 x 44 ~26 mm
XGS2220-54FP Yes Yes 441 x 330 x 44 ~26 mm
XS3800-28 Yes Yes 441 x 360 x 44 ~26 mm
GS1350-18HP Yes Yes 330 x 230 x 44 ~76.3 mm
GS1900-24EP Yes Yes 330 x 230 x 44 ~76.3 mm
GS1915-24EP Yes Yes 330 x 230 x 44 ~76.3 mm
XS1930-10 Yes Yes 330 x 230 x 44 ~76.3 mm
XS1930-12F Yes Yes 330 x 230 x 44 ~76.3 mm
XS1935-12F Yes Yes 330 x 230 x 44 ~76.3 mm
XS1930-12HP Yes Yes 330 x 230 x 44 ~76.3 mm
XMG1915-18EP Yes Yes 330 x 230 x 44 ~76.3 mm
XGS1210-12  No No 250 x 104 x 27 Desktop device
XGS1250-12  No No 250 x 104 x 27 Desktop device
GS1900-8 No No 250 x 104 x 27 Desktop device
GS1900-8HP No No 250 x 104 x 27 Desktop device
GS1900-10HP No No 250 x 104 x 27 Desktop device
GS1915-8 No No 250 x 104 x 27 Desktop device
GS1915-8EP No No 250 x 104 x 27 Desktop device
XMG1915-10E No No 250 x 104 x 27 Desktop device
XMG1915-10EP No No 250 x 104 x 27 Desktop device
XGS1010-12  No No 250 x 104 x 27 Desktop device
GS1100-10HP No No 250 x 104 x 27 Desktop device
GS1100-16 Yes No 215 x 133 x 42 ~134 mm
GS1100-16S Yes Yes 215.5 x 133 x 44 ~134 mm
GS1200-5 No No 121 x 75 x 26 Desktop device
GS-105BV3 No No 121 x 75 x 26 Desktop device
GS1005HP No No 121 x 75 x 26 Desktop device
GS-108BV5 No No 126 x 51.8 x 24 Desktop device
GS-108SV2 No No 138.1 x 67.6 x 28.6 Desktop device
GS1200-5HPV3 No No 155 × 85 × 26 Desktop device
GS1200-8 No No 155 x 85 x 26 Desktop device
GS-108BV3 No No 155 x 85 x 26 Desktop device
XMG-105 No No 160 x 110 x 26 Desktop device
XMG-105HP No No 160 x 110 x 26 Desktop device
GS1200-10V3 No No 193 × 85 × 26 Desktop device
GS1200-8HPV3 No No 193 × 85 × 26 Desktop device
GS1200-5HPV2 No No 193 x 84 x 26 Desktop device
GS1350-6HP No No 193 x 84 x 26 Desktop device
GS1200-8HPV2 No No 240 x 105 x 26 Desktop device
GS1008HP No No 240 x 105 x 26 Desktop device
XMG-108 No No 240 x 105 x 27 Desktop device
XMG-108HP No No 240 x 105 x 27 Desktop device
MG-108 No No 240 x 106 x 26 Desktop device
GS-105BV5 No No 82.5 x 46.8 x 24 Desktop device
GS-105SV2 No No 99.1 x 67.6 x 28.6 Desktop device
Articles in this section
Was this article helpful?
1 out of 1 found this helpful
Share
