Smart Managed Switch For Surveillance GS1350 Series
The GS1350 Series is designed specifically for video-surveillance networks. Its key branding phrase is “Just For Surveillance” — crafted for CCTV and IP-camera installations. Zyxel The switch belongs to the Zyxel NebulaFlex Pro family, offering flexible management between standalone and cloud modes.
What makes the GS1350 special for surveillance
  1. Surveillance-focused Web UI
    The GS1350 delivers a smart, intuitive user interface designed for camera environments: you can monitor PoE status and camera connectivity at a glance.
  2. Dual management mode with Nebula support
    You can switch between standalone and cloud management (Nebula) with ease. The series comes bundled with a 1-year Nebula Pro Pack, enabling cloud oversight.
  3. Dedicated PoE software features for surveillance
    • Auto Camera Recovery: automatically detect and restart failed IP-cameras or other PoE-powered devices using configurable parameters.
    • Continuous PoE: ensures uninterrupted PoE power to connected devices even during firmware upgrades or switch configuration changes, minimizing camera downtime.
  4. Extended-range deployment support
    The GS1350 allows using existing Cat 5e cables to reach up to 250 m, beyond the standard 100 m limit, which is ideal for remote camera placements.
  5. High PoE budget and rugged hardware design
    • Models support large PoE budgets (up to 375 W) to power multiple high-performance cameras.
    • Includes front-panel real-time PoE LED indicators and a one-touch “Restore” button for quick recovery from misconfiguration.
    • Built with robust protection: low-noise filtering, surge & ESD protection, isolated circuit design — all targeted for reliable surveillance environments.
Why this matters in surveillance networks
In installations such as campuses, parking lots, city-surveillance, or multiple remote sites, these capabilities bring real benefits:
  • Automatic recovery of failed cameras without physical site visits
  • Constant power delivery to cameras, reducing recording interruptions
  • Ability to deploy cameras far from the central rack using existing cables
  • High-budget PoE switch to handle many high-definition cameras
  • Cloud or local management flexibility, useful for multi-site surveillance setups
Quick Feature Recap
  • Surveillance-optimized user interface and device monitoring
  • Choice of standalone or cloud (Nebula) management with 1-year Pro Pack
  • Auto Camera Recovery and Continuous PoE for high reliability
  • Extended-range mode: up to 250 m Cat 5e deployment
  • Strong PoE budget (up to 375 W) and industrial-grade protection
Summary
If you’re building or upgrading a surveillance network and need a switch built for cameras, the GS1350 Series stands out. It goes beyond ordinary PoE delivery by adding features tailored for keeping IP-cameras powered, monitored and recovered — with the flexibility of both local and cloud management.
Note: Always check the exact model’s data sheet and firmware version on Zyxel’s official site to confirm that the features listed here (Auto Camera Recovery, Extended-Range, PoE budget, etc.) apply to your region and model.
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
