If your Zyxel device is experiencing unexpected behavior or you suspect it may be defective, this guide will help you understand the warranty replacement (RMA) process and direct you to the appropriate resources.
Rather than describing every step in detail, this article provides an overview of the complete RMA process and links to detailed instructions where needed. Hardware replacement is only considered after the reported issue has been evaluated and, where necessary, verified by Zyxel Technical Support
The RMA Process at a Glance
Before a warranty replacement can be approved, Zyxel Technical Support will first verify whether the issue can be resolved without replacing the device. In many cases, problems are caused by configuration, firmware, or environmental factors and can be resolved through troubleshooting.
The warranty replacement process typically consists of the following steps:
- Perform a self-check to confirm the issue is likely hardware-related.
- Check your warranty status to verify your device is eligible for warranty service.
- Open a Technical Support ticket through the Zyxel Support Portal.
- Work with Technical Support to complete the required troubleshooting and diagnostics.
- If a hardware failure is confirmed, your support engineer will convert the support ticket into an RMA case and arrange a replacement according to your warranty entitlement.
- Receive and verify the replacement device, then transfer licenses if applicable.
Each step is explained in detail below.
Step 1 — Before You Request an RMA
Before requesting a replacement, perform a few basic checks to ensure the issue is not caused by configuration, firmware, power supply, cabling, or other environmental factors.
✔ Verify that the device is receiving stable power (or PoE, if applicable).
✔ Test with another power adapter, Ethernet cable, or switch port whenever possible.
✔ Install the latest firmware available for your product.
✔ Perform a factory reset if configuration corruption is suspected.
✔ Review the User Guide or Knowledge Base for known issues and troubleshooting procedures.
✔ Contact Zyxel technical support if the issue could not be resolved.
Zyxel Support Portal – How to Contact Technical Support and Request Warranty Service
Step 2 – Check Warranty Status
Before submitting an RMA request, verify whether your product is still covered by warranty.
Use the official Warranty Checker:
- Zyxel Products Warranty - Products and Warranties
- Understanding Serial Number Verification Statuses
- Warranty Policy
If the warranty appears expired but you still have a valid proof of purchase, attach your purchase invoice when submitting the request. Zyxel Support will manually verify the warranty period, as the database may not always reflect the original purchase date.
Step 3 — Understand Available RMA Services
Depending on your product and region, Zyxel offers different replacement services.
| Service | Description |
| Standard RMA | Replacement is shipped after the hardware failure has been confirmed. |
| Standard+ RMA | Includes return logistics for the defective unit where available. |
| Next Business Day (NBD) | Available for eligible products with an active NBD license. The replacement unit is shipped on the next business day after approval. |
For a detailed comparison of each service, see: Zyxel Products RMA - Return and Replacement Services
Step 4 – Submit a Technical Support Request
Once you have confirmed that your product is eligible for warranty service, submit your RMA request through the Zyxel Support Portal.
Before creating the request, prepare the following information:
- Product model
- Serial number
- Detailed description of the problem
- Troubleshooting already performed
- Purchase invoice (if requested)
- Diagnostic files or logs (when requested by Technical Support)
Providing complete information helps reduce processing time: Zyxel Support Portal – How to Contact Technical Support and Request Warranty Service
Step 5 — License Transfer
Some Zyxel products include licenses that can be transferred to the replacement device after an approved RMA.
For supported products and instructions, refer to: Transferring Zyxel Licenses During an RMA: What You Need to Know and How to Request the Transfer
EOL / EOS and How It Affects RMA
When a device reaches EOL/EOS/EOSL (End of Life / End of Service / End of Support), warranty and RMA availability may be limited or discontinued. Before submitting an RMA, check whether your model is still supported.
Details available here:
ISP Devices
Many Zyxel devices are supplied and managed by Internet Service Providers (ISPs). These products may use customized firmware or be covered by a service agreement between the ISP and the end user.
If your device was provided by your ISP, warranty service, replacement, and technical support may be handled directly by the service provider instead of Zyxel.
Before submitting an RMA request through the Zyxel Support Portal, please contact your ISP to confirm the appropriate support and warranty process.
Zyxel SP Devices Explained: ISP Responsibility and How to Find Your Provider
Why an RMA Request May Be Declined
While Zyxel strives to provide warranty service whenever applicable, there are situations where an RMA request may not be approved. Common reasons include:
- Missing or Invalid Proof of Purchase – A valid proof of purchase may be required to verify warranty eligibility, particularly if the warranty cannot be confirmed automatically.
- Unsupported Third-Party Firmware – Devices running unsupported third-party firmware (such as OpenWrt or other unofficial software) may not be eligible for warranty replacement.
- Expired Warranty – Products outside the applicable warranty period may no longer qualify for warranty service unless otherwise specified by the applicable warranty policy.
- Incorrect or Missing Serial Number – The serial number is required to verify the product model and warranty status. Requests with invalid, incomplete, or unverifiable serial numbers cannot be processed until the information is corrected.
- ISP or Provider-Supplied Devices – If the device was supplied by an Internet Service Provider (ISP), mobile operator, or managed service provider, warranty and replacement services may be handled directly by the provider rather than by Zyxel.
- Physical Damage or Improper Use – Damage caused by accidents, misuse, liquid exposure, unauthorized repairs, modifications, or other conditions not covered by the warranty may result in the request being declined.
- No Hardware Defect Found – If troubleshooting and diagnostics determine that the reported issue is caused by software, configuration, or environmental factors rather than a hardware failure, an RMA may not be approved.
Note: The examples above represent the most common reasons why an RMA request may be declined, but they do not cover every possible scenario. Each request is reviewed individually by Zyxel Technical Support and evaluated based on the warranty terms, product lifecycle status, diagnostic results, and the specific circumstances of the reported issue. If additional information or troubleshooting is required, our support team will guide you through the process before making a final decision.
0 commentsPlease sign in to leave a comment.
