Zyxel Device Serial Number SN / Model - Where can I Find Serial Number or Model Name
This article explains how to find your device's Serial Number and model number. It also shows the devices' web interfaces. If to find your serial number, it starts with S (e.g. S140Z46002349).
Information Label
  • Example1: NWA50AX
  • Example 2: USG FLEX 100
  • Example 3: GS1915-8EP Switch
Device GUI or Utility GUI
Note:
If you do not have the device box and cannot find the serial number on the device case, you can find it in the device menu. This exception shows you how to find the serial number and model name of the LTE2566-M634 since it is not listed on the device itself.
  • Example 1: NWA50AX Access Point
  • Example 2: USG FLEX 100 Firewall
Package Box
Articles in this section
Was this article helpful?
45 out of 206 found this helpful
Share
