GS1200/XGS1210/XGS1250 - Configure Basic Setup, VLAN, LAG, Firmware Upgrade
This article will explain how to setup your switch device (XGS1210-12, XGS1250-12, GS1200-5(HPv2), GS1200-8(HPv2)) and configure a new IP address, DHCP, VLAN configuration, Link aggregation, Firmware upgrade via ZON & Web GUI as well as how to reach the device. This article will also show overheat protection (yellow exclamation mark), how to reset your switch if something goes wrong.
NOTE! Please upgrade the firmware to the latest version due to previous firmware issues on these models. Navigate to firmware upgrade in this article to see how.
1) Basic Setup
1.1 Login to the device
Note that the XGS1200-series are configured with static IP. So set your PC to static IP on the 192.168.1.0/24 range (for example 192.168.1.100) and then go to http://192.168.1.3 and enter the password 1234.
Login
1.2 Change IP Address
When you first login to the switch you will be prompted to change the IP address of the switch.
Switch IP address settings
Enable DHCP on the switch or keep it disabled and change the static IP of the device.
You can also navigate to "Management" on your switch GUI to change the IP address.
Switch management page
2) VLAN configuration
If you are unsure what to configure on the VLAN section, please read more about VLANs here.
2.1 How VLAN works
To get a basic understanding of VLANs and making a basic VLAN configuration working, you need to remember a few points:
1. You can only have 1 untagged membership per port
2. Untagged membership = PVID
2. Everything else should be tagged
3. Almost all computers cannot handled tagged traffic so it needs have a untagged VLAN on the port where you connect a PC
4. In some rare cases, these rules do not apply
2.2 Configure VLANs
To configure the VLAN, please choose the appropriate PVID of that port (usually management VLAN 1).
VLAN configuration page
Then to create a new VLAN, please press the "Create new VLAN" button below.
Then select the VLAN ID and mark the ports you want the new VLAN on. Usually, you will tag the new VLAN member because PVID 1 is the "Untag Egress Member". Make sure to mark VLAN2 as orange. Then hit "Apply".
VLAN member settings
2.3 VLAN Configuration Result
VLAN configuration result
Note! That usually, you can only use 1 untagged membership per port. We recommend you to configure VLAN 2 as a "Tag Egress Member" (select orange membership) and not untagged in this scenario.
3) Link Aggregation / Load Balancing
Link Aggregation (LAG) is taking two ports and combining /grouping these into one to get higher capacity (speed or reliability) on the link. Read more here.
The link aggregation configuration on these switches are very easy to configure, but also not customizable.
Link aggregation settings
You have four options:
- Link aggregation Port 1,2,3 and 4
- Link aggregation port 5 and 6
- Link aggregation port 7 and 8 and/or;
- Link aggregation port 9 and 10
3.1 LAG Abbreviations
MAC SA - Distribute traffic based on packet's source MAC address
MAC DA - Distribute traffic based on packet's destination MAC address
MAC SA & DA - Distribute traffic based on a combination of a packet's source and destination MAC address
4) Firmware Upgrade
This section will show you how to firmware upgrade your device to the latest device software.
4.1 Using ZON utility
Download Zyxel One Network Utility (ZON) and install it.
Select (mark) your device and then click on Firmware upgrade to upgrade the firmware on the selected device (7).
ZON utility device list
4.2 Using Web GUI
First download the latest firmware on https://download.zyxel.com, or go directly to the download page for your device here:
GS1200-8HPv2 - Download Page
XGS1250 - Download Page
XGS1210 - Download Page
Download the firmware and save it to your PC. Make sure to unzip the file you downloaded before proceeding.
Next, login to your switch (if you're having problems, click here) navigate to Management -> Firmware Upgrade
Firmware upgrade menu
Choose your unzipped firmware file by clicking the "Path" button and after you've selected the firmware, click upgrade.
Firmware upgrade path window
5) Troubleshooting
5.1 Reset the switch
If you're experiencing problems with your switch, it is a very good idea to reset your switch to factory default. To reset this switch, power on the device and then hold the RESET button for 15 seconds located to the bottom left of the hardware and then release it.
Front Panel
5.2 Auto-Negotiation - Link is only 100 Mbit/s
By default, the switch should auto-negotiate 1000 mbit/s (1 gbit) on the port with the device connected to that port, however in some cases, that might not be successful and you'll only see 100 mbit/s on a port.
Possible solutions is to;
a) Exchange the cable
Often, bad cables connected to the switch is often the main reason why the link is only 100 mbit/s. And if you would try to force the 1000 mbit/s on the switch, it will probably put "link down". Therefore, the switch cannot set the speed statically to 1 gbit/s to force the port to negotiate because the link will only go down.
b) Try another port
Next solution is to change the port to see if all ports behave the same.
c) Try another device with the same port and same cable
This will determine if there is something wrong with the network card of the device connected to the switch.
5.3 Broadcast Storm & Loop issues
If you suspect that you have Broadcast/Multicast storms in your network and on the switch, you might enable "Broadcast Storm Control" and set it to 100 pps (packets per second) as well as disable "Loop Prevention" to see if anything changes.
5.4 Overheat protection (Only XGS1250)
If the 10 gigabit ports overheats for too long, they will automatically decrease the port speed to 1 gbit for protection. You will see a little yellow exclamation mark icon next to its link status on the system screen. Make sure the environment is not exceeding 40 degrees Celsius.
Port status with speed warning
Click on the exclamation mark to return to 10 gbit speed again on the 10 gbit port.
Overheat protection message
Articles in this section
Was this article helpful?
10 out of 19 found this helpful
Share
