Zyxel LTE7240-M403 LTE router- Review and Setup Guide
The Zyxel LTE7240-M403 is a robust, easy-to-install outdoor LTE router designed to provide high-speed internet connectivity, especially in rural or suburban areas where wired connections are not readily available. This device is perfect for both small office and home networks and is equipped with features like LTE support, a PoE injector for efficient power management, and a resilient firewall.
Note: The LTE7240-M403 can only be powered with the Passive PoE Injector / Adaptor. Please also see the Products Datasheet:
  • Passive Power over Ethernet
  • Power consumption at jack: < 10W
  • 15V/1A Power over Ethernet (PoE)
Key Features
  • Outdoor-ready: The LTE7240-M403 is built to withstand outdoor conditions, making it suitable for areas where indoor placement may compromise signal quality.
  • Gigabit Ethernet Port: Offers high-speed LAN connectivity.
  • SIM Card Slot: Allows for seamless LTE connection by inserting a compatible SIM card.
  • Firewall Protection: The device comes with Stateful Packet Inspection (SPI) to guard against threats like Denial of Service (DoS) attacks.
  • Easy Management: Configuration is accessible through a Web Configurator, offering flexibility and ease of use.
Note: For more information on all the features of the device, please see the link: Specifications
Initial Setup and Configuration Guide
  • Ensure your Zyxel Device hardware is connected correctly (refer to the Quick Start Guide).
  • Launch your web browser.
  • Type "192.168.1.1" as the URL.
  • A password screen displays. Welcome to the Zyxel Device configuration interface. Type “admin” as the default Username and “1234” as the default password to access the Web Configurator.
  •  Then click Login. If you have changed the password, enter your password and click Login.
The Quick Start screen displays the first time after you change the password in your device’s Web Configurator. You can also click the Quick Start icon in the Connection Status screen to open the Quick Start screens. The wizard will guide you through the basic settings of the Zyxel Device. This will take about a few minutes to complete. Click Close to leave the Wizard screens without saving your changes.
  • Select the time zone where your device is located. Click Next.
  • Wireless Setup The following settings are the current WiFi settings which your wireless client devices need in order to get connected to the Zyxel Device. Enable the wireless service and click Save.
  • Connection Status - Click Status to display the Status screen, where you can view the Zyxel Device’s interface and system information.
Web Configurator in Status Layout
As illustrated above, the main screen is divided into these parts:
  • A - title bar
  • B - main window
  • C - navigation panel
Final Thoughts
The Zyxel LTE7240-M403 is an excellent choice for users needing a reliable and fast LTE connection. With straightforward setup steps and robust security features, it provides a dependable internet solution, especially for outdoor and remote applications.
Articles in this section
Was this article helpful?
2 out of 3 found this helpful
Share
