Zyxel LTE 3302 Mobile Broadband - basic configuration and troubleshooting
This article provides a comprehensive guide on using the Zyxel LTE3302 router, including initial login, Wi-Fi configuration (SSID and password changes), LAN IP address modification, content filter setup, firmware upgrading, and troubleshooting.
Before starting, check that everything is connected correctly and the unit is turned on. Also, in the photo below, you will find a description of the colour indication for a more transparent understanding of the device's behaviour.
⚠️ Please note: This device is currently in EOL (End of Life) status. Support and firmware updates may be limited, and technical assistance might not be fully available. For additional help, we recommend visiting the Zyxel Knowledge Base and the official community forum. To maintain reliable performance and access to full support, consider upgrading to a newer model.
Press the button next to the mini-SIM card slot to release the tray. Position a mini-SIM card in the tray as shown and slide the tray back into the LTE3302. If you are using a micro-SIM or a nano-SIM card, correctly insert it securely into the SIM card adapter to avoid possible damage to your device. Select the type of plug used in your country. Insert the plug in the micro USB power adaptor until you hear a "click".  Use the included power adaptor (that has an output of 5V at 2A or higher current) to connect the LTE3302 micro USB port to an appropriate power outlet. Press the POWER button to turn on the LTE3302.
First Login via Computer or Mobile Device
Connect your computer directly to one of the LAN ports of the LTE3302 or connect to the pre-configured WiFi (SSID and PSK are stated on the back of the device)
or
Connect your mobile device to the LTE3302 wirelessly. Open the web browser from your mobile device and enter the default management IP address (192.168.1.1). Enter the user name admin and password 1234, then tap Login.
Default Login Details:
At the first login, the system will ask you to change your password by setting a strong password. Next, log in and proceed to the WIFI setup.
Configure WIFI on LTE 3302 (Change SSID name and WIFI password)
 Go to Configuration > Network > Wireless LAN
  • Change the Name (SSID) of the WiFi and the PSK.
  • Ensure you have entered the right PSK, you can tick "Show Password"
  • Click on "Apply" to save the changes
Changing LAN IP Address LTE 3302
Go to Configuration > Network > LAN
  • Change the IP address and the subnet mask of your LTE3302
  • Click on "Apply" to save your changes.
Your LTE3302 is now reachable under the new IP Address
Content Filter Setup on LTE 3302
Go to Configuration > Security > Content Filter
  • Set the blocked websites in the keyword list by entering the URL and click on "Add"
  • Enter an IP address from a specific PC in your network to a trusted computer IP Address. This computer will be able to ignore the keyword list.
  • Click on "Apply" to save the changes.
Firmware Upgrade
Download the Latest Firmware
  • Go to Download Library
  • You can find your device model (LTE3302-M432) and download the latest firmware file. The firmware file typically has a .bin extension (e.g., V1.00(ABKQ.1)C0).
  • If the downloaded file is compressed (e.g., in a .zip format), unzip it to access the .bin file.
Access the Firmware Upgrade Screen
  • Log in to the Web Configurator by entering the device’s IP address into your web browser.
  • Navigate to Maintenance > Firmware Upgrade from the main menu.
  • The Firmware Upgrade screen will allow you to upload the new firmware file.
Upload the Firmware
  • Click on the Choose File button and select the .bin file you downloaded.
  • Once selected, click Upload to begin the upgrade process.
  • Important: Do not turn off the device or disconnect it from the power source during the upgrade process.
Wait for the Upgrade to Complete
  •  After clicking Upload, the firmware upload process will begin. This process may take up to two minutes.
  • Once the upload is successful, the device will automatically restart. During this time, you may experience a temporary network disconnect.
  • Please do not attempt to log in or power off the device until it has rebooted.
Verify the Firmware Upgrade
  • After the device has restarted, log in again to the Web Configurator.
  • Navigate to the Status screen to confirm that the firmware version has been updated.
Firmware to (re)flash LTE3302-M432
At the end of the article, attached is the firmware file you can use if you need to (re)flash your device.
Troubleshooting Guide
Problem: The LTE Device does not turn on (None of the LEDs are on).
  • Check the Power Adaptor: Ensure you are using the power adaptor included with the LTE Device.
  • Verify Power Connection: Confirm that the power adaptor is securely connected to the LTE Device and plugged into a functioning power outlet. Ensure that the power source is turned on.
  • Reconnect Power: Disconnect and then reconnect the power adaptor to the LTE Device.
  • Contact Vendor: If the problem persists, contact us for further assistance.
Problem: One of the LEDs is not behaving as expected.
  • Understand Normal LED Behavior: Review the expected behaviour of the LEDs as outlined in the device manual.
  • Check Hardware Connections: Ensure all hardware connections are secure. Refer to the Quick Start Guide for proper setup.
  • Inspect Cables: Check all cables for any visible damage. Replace any damaged cables.
  • Reconnect Power: Disconnect and reconnect the power adaptor to the LTE Device.
  • Contact Vendor: If the issue continues, contact the vendor for support.
Problem: The Battery LED is alternating between green and amber.
  • Wrong Battery Type: Ensure you are using the correct type of battery for the LTE Device.
  • Inspect the Battery: Check the battery for any signs of damage. If damaged, contact the vendor to replace the battery.
  • Reinsert Battery: If the battery was removed while charging, reinstall it to continue charging. Removing the battery during charging may shorten its lifespan.
  • Check Battery Temperature: If the battery is too hot or too cold, remove it and allow it to cool or warm up. Ensure the device is not in an enclosed or poorly ventilated space.
Problem: I forgot the password.
  • Factory Reset: Use the RESET button at the back of the device to reload the factory-default configuration. This will reset the password to “1234” and the IP address to “192.168.1.1”.
  • Ensure Power LED is On: Before performing a reset, make sure the POWER LED is on.
  • Reset Procedure: Press the RESET button for five seconds to restore factory settings, or for two seconds to simply restart the device.
Problem: I cannot see or access the Login screen in the Web Configurator.
  • Browser Settings: Ensure that your browser allows pop-ups and has JavaScript enabled.
  • LAN Connection: Make sure you are logging in from the LAN side, and your computer is in the same subnet as the LTE Device.
  • Factory Reset: If necessary, reset the device to factory settings and attempt to access the Web Configurator using the default IP address.
Problem: I can see the Login screen, but I cannot log in.
  • Verify Credentials: Ensure the username and password are entered correctly. The default username is “admin” and the default password is “1234”.
  • Session Timeout: If you failed to log out properly in the last session, wait five minutes and try logging in again.
  • Power Cycle: Disconnect and reconnect the power adaptor to restart the device.
  • Factory Reset: If login issues persist, perform a factory reset.
Problem: I cannot access the Internet.
  • Check Hardware Connections: Ensure all cables are connected correctly and that the LEDs are functioning as expected.
  • Verify Mobile Access Information: Double-check that your APN and other mobile access settings are entered correctly.
  • SIM Card Status: Ensure your SIM card account is valid and has an active data plan.
  • Contact ISP: If issues persist, contact your Internet Service Provider (ISP) for assistance.
Problem: The Internet connection is slow or intermittent.
  • Network Traffic: High traffic on the network can cause slow connections. Close programs that use a lot of bandwidth, such as peer-to-peer applications.
  • Signal Strength: Check the signal strength. If it is low, move the LTE Device closer to the base station or eliminate sources of interference, such as microwaves or other wireless networks.
  • Use External Antennas: Connect external antennas to improve signal strength and position them for optimal reception.
  • Reboot the Device: Restart the LTE Device to refresh the connection.
Problem: I cannot access the LTE Device or ping any computer from the WLAN.
  • Enable Wireless LAN: Ensure that the wireless LAN is enabled on the LTE Device.
  • Check Wireless Adapter: Verify that the wireless adapter on your computer is working correctly and is compatible with the LTE Device.
  • Ensure Compatibility: Confirm that both the LTE Device and your computer's wireless adapter are using the same WiFi and security settings.
  • Check Range: Make sure your computer is within the transmission range of the LTE Device.
Problem: Intermittent or unstable WiFi connection.
  • Reduce Interference: Identify and eliminate sources of interference such as walls, metal objects, or electrical devices like microwaves and cordless phones.
  • Optimize Positioning: Move your device closer to the LTE Device if the signal is weak and ensure there are minimal obstacles between them.
  • Manage Wireless Clients: Reduce the number of devices connected to the LTE Device or consider adding additional access points to the network.
This guide covers the most common issues. If the problem persists after following these steps, please consult the device’s user manual or contact customer support for further assistance.
Articles in this section
Was this article helpful?
12 out of 32 found this helpful
Share
