NR5101 - How to use the External Antennas
In this article, we will look at the external Antennas of the NR5101 and the Limitations.
Let's have a look at the Back of the Device:
1) Hardware Switch to switch between the Internal and External Antennas
2) SMA connectors for the external Antennas
Antenna Limitations:
The NR5101's external antenna and device ability support 3300-4200 MHz.
Both Antennas have to be connected as they provide Mult-Mimo.
To use the external Antennas, connect them to the external connectors and flick the switch to the "ext." Position.
The Device now uses the external Antennas.
Articles in this section
Was this article helpful?
43 out of 83 found this helpful
Share
