Zyxel 5G Devices NR Series - Advanced Downloads Firmware and other resources
This article provides essential updates for Zyxel's 5G NR series devices, including the NR5101, NR7101,NR7102, NR5103 and NR2101, NR2101. We highly recommend utilizing the latest updates for your  device, as these updates address numerous known issues and vulnerabilities. Installing the updates is a straightforward process and can effectively resolve concerns related to signal quality, device stability, unexpected crashes, and unscheduled reboots. Furthermore, these updates address issues related to SIM card detection and other challenges associated with provider settings. Please make sure that performance and security is maintained by quickly applying the latest updates to your Zyxel 5G NR series device.
Disclaimer!  This article offers a general overview of the series and may not apply uniformly to every model,  software/firmware version. Prior to purchasing or using the device, please consult the  model/version-specific documentation or reach out to technical support for accurate information.
Note: To access Voice over LTE (VoLTE) features offered by ISPs for making calls over LTE/4G. Due to the complexity of VoLTE configurations, Zyxel firmware does not support VoLTE. Since each provider has unique VoLTE configurations, it is best to purchase Zyxel equipment from your provider. As a workaround, you can configure the LTE router for 3G only to enable VoLTE, but this will not work in regions such as Germany, where 3G is unavailable.
Note:  Not every firmware may work in every country. You can refer to the "digits", i.e. "AAYE", if your current firmware on the device matches this article to install a new one. It could also happen that you already have a newer firmware on your device as available within this article. If you need any assistance, please get in touch with our Support Team!
Note: We recommend avoiding LTE (radio) module firmware updates unless necessary, as they can sometimes reduce device performance. LTE (radio) is often tailored to specific regions and network settings. If your device is stable, updating the device firmware only, not the LTE module, is sufficient.
The module firmware names indicate both the version to be installed and the one to which you can upgrade. All updates must be installed sequentially, following the correct order, one by one.
  • G502QEAAAR01A04-R11A03 - R11A03 Firmware - (from R01 (A04) to R11 (A03))
  • RG502QEAAAR11A03-R11A06 - R11A06 Firmware - (from A03 to A06)
  • RG502QEAAAR11A06M4G - R11A07  Firmware - (from A06 to A07)
  • RG502QEA_R11A07 - ZYXELR13A02 Firmware - (from R11A07 to ZYXELR13A02)
  • ZYXELR13A02 - ZYXELR13A04 Firmware - (from ZYXELR13A02 to ZYXELR13A04)
NR7101 - Troubleshooting LTE Module update issues in NR7101
If you have trouble installing the latest version of the update, please follow the steps below. This procedure is only suitable if the LTE module version RG502QEAAAR13A02M4G is installed.
Note:
Each update step can take up to 10 minutes. After each step, you should reboot your device and check the current firmware version. It is also strongly recommended that you remove the SIM card from the device during the LTE module update.
  1. Download the following file and downgrade it to R11A07 first: EAAAR13A02M4G-EAAAR11A07M4G.zip
  2. Reboot the device and check that the firmware version is RG502QEAAAR11A07M4G.
  3. Next, update the device's firmware to the latest version. If this step has already been completed, you may skip it. The latest firmware version is V1.00(ABUV.10)C0
  4. Download the following update and install it: RG502QEA_R11A07-ZYXELR13A02
  5. Reboot the device and check that the firmware version is ZYXELR13A02.
  6. Download the following update and install it: ZYXELR13A02 - ZYXELR13A04
NR2301
Version Type Download
NR2301_V1.00_Manual User Guide Download Now!
NR2301_V1.00(ACIY.3)C0 Firmware Download Now!
NR2301_V1.00(ACIY.2)C0 Firmware Download Now!
NR2301_V1.00(ACIY.1)C0 Firmware Download Now!
 V1.00(ABVC.10)C0  Firmware Download Now!
 V1.00(ABVC.6)C1  Firmware Download Now!
V1.00(ABVC.6)C0 Firmware Download Now!
V1.00(ABVC.5)C0 Firmware Download Now!
NR5101_UG_v1-0_ed1_2021-01-08 User Guide Download Now!
How to Update Cellular Module Firmware Via WebGUI  Modem Upgrade SOP Download Now!
RG502QEAAAR11A03M4G.img Modem Code File Download Now!
RG502QEAACR13A02M4G_ZYXEL Modem Code File Download Now!
  RG502QEAACR13A04M4G_ZYXEL Modem Code File and User Guide Download Now!
NR5103 (NOT NR5103E)
NR5103_User's_guide_V1.0-4.4 User Guide  Download Now!
V4.19(ABYC.5)C0 Firmware Download Now!
V4.19(ABYC.3)C0 Firmware Download Now!
NR7101
  V1.00(ABUV.11)C0  Firmware  Download Now!
  V1.00(ABUV.10)C0  Firmware  Download Now!
V1.00(ABUV.8)C0 Firmware  Download Now!
NR7101_UG_v1-0_ed1_2020-04-20 User Guide Download Now!
RG502QEAAAR01A04-R11A03 Modem Code  Download Now!
RG502QEAAAR11A03-R11A06 Modem Code  Download Now!
RG502QEAAAR11A06M4G-R11A07 Modem Code  Download Now!
RG502QEA_R11A07-ZYXELR13A02 Modem Code  Download Now!
  ZYXELR13A02 - ZYXELR13A04  Modem Code  Download Now!
NR7102
Quick Start Guide User Guide Download now
1.00(ABYD.2)C0 Firmware  Download now
1.00(ABYD.2)C0 FW release  FW release Download now
1.00(ABYD.3)C0 Firmware  Download now
1.00(ABYD.3C0 FW release  FW release Download now
1.00(ABYD.4)C0
Firmware
Download now
RG502QEUAAR12A03M4G Modem Code  the latest version
Note for NR7102: The firmware update already includes the latest radio module update. There's no need to update the radio module separately.
Articles in this section
Was this article helpful?
49 out of 170 found this helpful
Share
2 comments
Article is closed for comments.
  • NR7101 - Module firmware Upgrade RG502QEAAAR11R13A02-R13A04 - not working
  • Greetings Paweł Wajwer!
    Thank you for your message and for pointing out this problem.
    We have fixed it.
