How to Capture Network Packets Using Wireshark
Sometimes Zyxel Support needs a packet capture to find the cause of a network problem.
Wireshark is a free network protocol analyzer that can capture network traffic and save it to a .pcapng file. This file can be shared with Zyxel Support for troubleshooting.
This article explains how to capture packets using Wireshark.
Before You Start
Before you begin, make sure that:
  • Wireshark is installed on your computer.
  • You know which network adapter is connected to the network.
  • You have enough free disk space to save the capture file.
Note: Start the packet capture before you reproduce the issue. This helps capture the complete communication.
Step 1 – Open Wireshark
Open Wireshark.
The main window shows all available network adapters.
Select the adapter that is connected to the network where the problem occurs.
Open Wireshark
Step 2 – Start Packet Capture
Click the Start Capturing Packets button (blue shark fin).
Wireshark will immediately begin capturing network traffic.
Step 3 – Reproduce the Issue
While Wireshark is running:
  • Perform the action that causes the problem.
  • Wait until the issue appears.
  • Continue capturing for another 10–20 seconds.
This allows Zyxel Support to analyze the traffic before, during, and after the issue.
Step 4 – Stop Packet Capture
Click the Stop Capturing Packets button (red square).
Stop Packet Capture
Step 5 – Save the Capture File
Go to:
File → Save As
Save the file in the default .pcapng format.
Example:
 Save As
 Save As
Useful Display Filters
Display filters help you find specific packets after the capture is finished.
Purpose Filter
One IP address ip.addr == 192.168.1.10
TCP port tcp.port == 443
UDP port udp.port == 500
DNS dns
DHCP bootp
ARP arp
ICMP (Ping) icmp
HTTPS (TLS) tls
HTTP http
IKE VPN isakmp
IPSec ESP esp
  • ip.addr == 192.168.168.48
Capture Filters (Optional)
Capture filters reduce the amount of traffic before the capture starts.
Capture one host:
Examples:
Capture one host:
host 192.168.168.48
Capture one port:
port 443
Capture DNS traffic:
port 53
Important: Capture Filters are different from Display Filters. Capture Filters work before the capture starts, while Display Filters work after the capture is completed.
Best Practices
For the best troubleshooting results:
  • Start the capture before reproducing the issue.
  • Stop the capture 10–20 seconds after the issue occurs.
  • Save the complete capture file.
  • Do not remove packets from the file.
  • Save the file as .pcapng.
  • If possible, note the exact time when the issue occurred.
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
