How to Enable and Check Debug Level (log level 8) on Zyxel USG FLEX H Series
When troubleshooting complex network issues or analyzing system performance, accessing detailed kernel logs can be essential. The Zyxel USG FLEX H Series firewalls provide a flexible debug level control that allows administrators to capture in-depth system activity for diagnostics and long-term monitoring.
In this guide, you will learn how to:
  • change the kernel debug level from the console;
  • verify the current debug configuration;
  • use the output for advanced troubleshooting and log analysis.
On the console, enter the command to change dthe ebug level.
usgflex500h> cmd debug kernel console-level 8
Check the debug level.
usgflex500h> cmd debug kernel console-level show
kernel console-level: 8
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
