Zyxel Multy Plus PPPoE / Static IP - how to set up PPPoE or Static IP on Multy App
This article provides a detailed guide on how to configure your Multy App to use either PPPoE (Point-to-Point Protocol over Ethernet) or a Static IP address. By following the instructions outlined here, you will be able to customize your Multy device according to your network requirements.
End-of-Life (EOL) Notice
This is to inform you that the product Multy M1 (WSM20)/Multy Mini(WSQ20)/Multy Plus (WSQ60)/Multy U (WSR30)/Multy X (WSQ50) has officially reached its End-of-Life (EOL) status. As a result, technical support is no longer guaranteed. Any further use, configuration, or modification is performed at your own risk. We appreciate your understanding.
By default, the Multy device is set up as a DHCP (Dynamic Host Configuration Protocol) client. This means it automatically receives an IP address from the network's DHCP server without any manual configuration. However, there may be situations where you need to set up your Multy device to use PPPoE or a Static IP address instead. For instance, certain Internet Service Providers (ISPs) require PPPoE for authentication purposes, or you might need a Static IP for specific networking needs such as remote access or hosting a server. The following steps will guide you through the process of configuring your Multy device to meet these requirements.
  • Connect the WAN port of Multy to your Router/Modem, and set your Multy as below Topology.
  • Open your Multy App and follow the instruction to install the Multy as below.
  • Please wait for 30 seconds then select the option "Manual Setup Connection".
  • Type in the PPPoE account information or the static IP to finish the setup.
  • After the installation finished, please make sure that the WAN IP is a public IP.
  • You can check it on the Multy App > Multy Icon > WAN IP.
Articles in this section
Was this article helpful?
2 out of 3 found this helpful
Share
