Zyxel Multy APP - Multy App first start and installation
Getting started with the Multy App is a straightforward process, but ensuring a smooth installation requires a few key steps. To initiate the setup, simply open the Multy App on your device. It's important to note that a stable internet connection is essential for the installation to proceed without issues. By following these steps, you'll be ready to utilise the Multy App's features fully.
Zyxel Multy for Apple
Zyxel Multy for Android
End-of-Life (EOL) Notice
This is to inform you that the product Multy M1 (WSM20)/Multy Mini(WSQ20)/Multy Plus (WSQ60)/Multy U (WSR30)/Multy X (WSQ50) has officially reached its End-of-Life (EOL) status. As a result, technical support is no longer guaranteed. Any further use, configuration, or modification is performed at your own risk. We appreciate your understanding.
While the App is detecting the Multy via Bluetooth, please wait for 1~2 minutes for the next step. The app will inform users that we have an urgent update, please wait for a few minutes, Multy is creating the wifi network, so please keep following the instructions.
The app will ask for your permission to connect the default SSID of Multy, then your phone will connect to the MULTY_XXXX SSID, and start to renew the certificate. You may notice the wifi has switched to the Multy SSID.
Please keep following the steps to finish your setup along with a firmware upgrade.
Once the installation and the firmware upgrade are complete, your Multy should be ready.
Note: the WiFi SSID and Password will be MULTY_XXXX and the MAC Address of your Multy. You can change the SSID and Password on the WiFi Settings.
Articles in this section
Was this article helpful?
2 out of 4 found this helpful
Share
