Zyxel Multy SSID/WIFI - WI-FI SSID settings on Zyxel Multy Devices
This article will explore key tips for managing your Zyxel Multy devices to optimize your home network. Learn how to customize your 2.4G and 5G SSID names, turn off Wi-Fi on your Multy-X (WSQ50), and update your Wi-Fi password for enhanced security and convenience.
End-of-Life (EOL) Notice
This is to inform you that the product Multy M1 (WSM20)/Multy Mini(WSQ20)/Multy Plus (WSQ60)/Multy U (WSR30)/Multy X (WSQ50) has officially reached its End-of-Life (EOL) status. As a result, technical support is no longer guaranteed. Any further use, configuration, or modification is performed at your own risk. We appreciate your understanding.
Change SSID names for your 2.4G and 5G
  • Go to the Wifi Settings
  • Click on the Settings for your Wifi
  • Click on the ticked box to separate the SSID (Wifi) for 2.4G and 5G and untick it.
  • Now you can enter different names for your 2.4G and 5G Wifi and save it
Сhange Password on Multy WiFi
  • Go to WIFI Settings
  • Tap on the "Edit" symbol
  • Edit the password and Tap on Save
After you tap on save, you will be prompted to confirm the change as it will take a while to send the change to every unit in your Multy network. When the update is done, you will be returned to your home screen and your WiFi password is changed.
Turn off Wi-Fi on a Multy-X (WSQ50)
  • Click change WIFI
  • Turn off Wi-Fi by flipping the switch
undefined
Articles in this section
Was this article helpful?
8 out of 22 found this helpful
Share
