Zyxel Multy Bridge / NAT - how to use Bridge / NAT mode on Multy?
Suppose you already have an existing network with several network components such as switches, NAS, maybe a server, etc. and you want to use Multys only as a WiFi solution. Then you have the option to use Multys in bridge mode.
End-of-Life (EOL) Notice
This is to inform you that the product Multy M1 (WSM20)/Multy Mini(WSQ20)/Multy Plus (WSQ60)/Multy U (WSR30)/Multy X (WSQ50) has officially reached its End-of-Life (EOL) status. As a result, technical support is no longer guaranteed. Any further use, configuration, or modification is performed at your own risk. We appreciate your understanding.
  • Go to Zyxel Multy App
  • Choose "Home"
  • Choose "Settings"
  • Go to "NAT mode"
  • Tap on "NAT (Standard) - Mode"
Note:
  • If you using features like Parental Control, UPnP, reserved IP for a device, Port forwarding or the DMZ of the Multys, these features will be disabled!
  • The Multy X does not support client mode
Articles in this section
Was this article helpful?
2 out of 11 found this helpful
Share
