Zyxel Multy U Basic Setup - Basic Setup Guide for Adding a New Site and Integrating Multiple Devices via the Multy App
This is a step-by-step to show you how to set up a Multy network using Multy U and the Multy App. In this scenario, we will create a new site and add both Multy Us to create a WiFi mesh. We decide which Network name we want to use and which password it should have.
End-of-Life (EOL) Notice
This is to inform you that the product Multy M1 (WSM20)/Multy Mini(WSQ20)/Multy Plus (WSQ60)/Multy U (WSR30)/Multy X (WSQ50) has officially reached its End-of-Life (EOL) status. As a result, technical support is no longer guaranteed. Any further use, configuration, or modification is performed at your own risk. We appreciate your understanding.
Add new Multy
  • Open your App and make sure that you are logged in
  • Tap on the blue marked button to add a Multy to a new Multy site
  • Choose a name for your site
  • Select the device you want to add (In this example, we chose the Multy U)
  • Follow the instructions on the screen to prepare the Multy
  • Unplug the modem to start from a new network
  • Connect the Multy to your modem/router
  • Power on both router/mode and your Multy device
  • Wait for 2 minutes. Tap below, when the Multy LED is blue and tap on the button below.
    Now the Multy App tries to establish a connection to your Multy If this succeeds you will see the following screen where you can choose in which room the Multy is
  • If you tap on next you will have to wait until until the Internet connection has been tested successfully.
WiFi Setup
  • You can assign different names to the 2.4G and 5G networks and of course a password. If you are done, please tap on "Create" and wait 30-120 seconds:
  • The creation of your first Multy WiFi will be confirmed
Add additional Multy
  • You can now choose to leave it at one Multy, or add another Multy to the site
  • Click on "Add Multy" to add another Multy
  • Check the distance between both Multy devices
  • Power up the Multy and wait until the Multy LED is blue
  • If Multy LED is blue, tap on "It's solid blue" and you will see the following screen
  • After the connectivity check is done successfully, both Multy's will be paired via Bluetooth:
  • If this is successful you will see the following screen
  • The "Location Check" will make sure that the distance between both Multy's is not too far and not too near
  • If you need to change the distance, the app will tell you in what direction you have to change it
  • When the check is done and successful you will be forwarded to the next screen, where you have to choose the location of the Multy
  • You have now successfully added the Multy to your site
  • The following screens are informational screens about your WiFi and general wiring:
Your home screen should look like this now
Congratulations, you have now successfully added two Multy to your site and can enjoy WiFi!
Articles in this section
Was this article helpful?
2 out of 14 found this helpful
Share
