How to Check Nebula Information on Zyxel USG FLEX H Series via CLI
This article explains how to quickly verify Nebula Control Center connection details on Zyxel USG FLEX and ATP firewalls using the CLI. The show gui nebula info command helps confirm the assigned organization, site, and management subnets.
❓ Question
How can I check Nebula organization, site, and subnet information on a Zyxel USG FLEX device?
✅ Answer
To display Nebula-related information, run the following command in the CLI:
This command shows:
  • organization-name — the Nebula organization the device belongs to
  • site-name — the Nebula site name
  • interface-setting — IP subnets used by the device for Nebula/GUI access
Notes:
  • This is a read-only diagnostic command and does not modify the configuration.
  • Useful for:
    • verifying Nebula registration
    • checking correct organization and site assignment
    • troubleshooting Nebula connectivity or access issues
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
