FAQ-E - Is HA Support on USG FLEX H uOS in Nebula?
Q: Is HA supported in Nebula mode on USG FLEX H with uOS?
A: Yes, HA Pro is supported on USG FLEX H with uOS, but not directly through the Nebula cloud interface.
To use HA, the device must be registered in Nebula, but all HA configuration and management are done entirely via the local web interface. This setup is often referred to as a hybrid mode — the device is visible in Nebula for licensing and monitoring, but advanced functions, such as HA, are handled locally.
Instructions for the USG FLEX H Series
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
