What happens if you set automatic firmware updates for Zyxel H-Series in both Nebula and the local interface?
Can I use automatic firmware updates in Nebula Control Centre (NCC) and in the local device interface at the same time?
Answer:
Technically yes, but it is not recommended, because it can cause conflicts or unexpected updates.
Question:
What happens if updates are scheduled at different times or at the same time?
Answer:
The system will run the update that is scheduled first.
However, if one update is already done, the second one may not be needed or could cause problems.
Question:
How should I set up automatic updates correctly?
Answer:
It is recommended to use only one update method:
  • If you use Nebula, turn off the local scheduler on the device.
  • Or, if you manage the device locally, use only the Web GUI.
Conclusion:
To avoid conflicts and keep your device working smoothly, use only one update schedule — either from Nebula or from the local interface, but not both at the same time.
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
