NWA50AX / NWA90AX / NWA55AXE- Configure the device using the Nebula APP
This article explains how to configure NWA50AX/NWA90AX/NWA55AXE using the Nebula application on your mobile phone or tablet (iPhone/Android). The NWA50AX from Zyxel is a real WiFi 6 AP with the right range of functions for small businesses and SOHO users who want to upgrade to 11ax (WiFi 6) without digging too deep into their pockets. The NWA50AX supports both 2.4 GHz and 5 GHz and allows you to enjoy all the benefits of WiFi 6 such as: For example, faster speeds even when congested or in high-density environments, extended range in your WLAN, increased capacity for IoT implementations and much more. The NWA50AX with NebulaFlex gives you flexibility in management, so you can freely choose between management via the local user interface or via our super simple Nebula cloud management interface. You never have to worry again whether you remember the IP address or account and password.
How to start configuring your device
Step 1.
Download and install the Nebula App from App store or Play Store:
Step 2. Create a Nebula account:
Step 3. Scan the QR code
Scan the QR code that's on the package or on the device's back side:
Step 4. Connect the device and complete the installation
Connect the device to your router and connect the power cable to the socket. Wait until the
Installation Complete
Wait up to 5 minutes for the device to come online and the WiFi should show up in your mobile phone:
P.S. You can also configure your Nebula devices on https://nebula.zyxel.com
Articles in this section
Was this article helpful?
11 out of 65 found this helpful
Share
