Zyxel Nebula WLAN Neighbor Scan Live Tool
Neighbor Scan Live Tool is a built-in tool in NCC (Nebula Control Center). It shows a list of devices that send beacon frames or reply to probe requests near the access point.
Main features
  • The access point scans all supported radio bands and channels.
  • The list shows only nearby devices. It does not show signals from the local AP.
  • The list supports sorting only (by default, it is sorted by Last Seen).
  • Filtering and exporting data are not supported in this version.
How It Works
During the scan, the access point checks the radio environment and creates a list of detected BSSIDs with the following information:
  • BSSID
  • SSID
  • Channel
  • Band
  • 802.11 Mode
  • Security
  • Last Seen
Last Seen Parameter
The Last Seen field shows the time when the network was last detected during the scan.
  • The value is updated when the same network is found again.
  • By default, the list is sorted by the time of the last detection.
  • If the network is not detected again, the entry stays in the list for up to 90 minutes.
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
