Zyxel Firewall H Series Security Policy - How to Detect and Prevent TCP Port Scanning with DoS Prevention
This article explains how to configure a USG FLEX H DoS Prevention profile to detect and block TCP port scanning attempts. The DoS Prevention feature analyzes network traffic for protocol anomalies, RFC violations (Requests for Comments), and suspicious traffic patterns, helping to protect the network from reconnaissance activities before an attack occurs.
Enhanced DoS Prevention
Starting from firmware version 1.38, the USG FLEX H Series introduces an enhanced DoS Prevention engine designed to improve the detection and mitigation of port scanning and flooding attacks.
The enhanced mechanism analyzes suspicious traffic at an earlier stage of packet processing, allowing the firewall to detect and block malicious traffic before it consumes unnecessary system resources. This approach improves overall performance by reducing CPU utilization while maintaining effective protection against reconnaissance activities.
The DoS Prevention engine supports detection of multiple scan and flood attack types, including:
  • TCP Port Scan
  • UDP Port Scan
  • IP Protocol Scan
  • TCP Sweep
  • UDP Sweep
  • ICMP Sweep
  • IP Protocol Sweep
  • TCP Flood
  • UDP Flood
  • ICMP Flood
  • IP Flood
Each detection rule can be individually configured to log events, block offending hosts, and automatically blacklist source IP addresses for a configurable period.
Set Up the DoS Prevention
In the USG Flex H, go to Security Policy > Dos Prevention > Add a profile. Configure a Name for you to identify the profile such as “DoS_Prevention”. Configure the Scan Detection and Flood Detection to block when the Dos prevention events were detected.
DoS Prevention Policy – defines on which interfaces the protection is applied.
DoS Prevention Profile – defines which anomalies are detected and how the firewall responds.
Step 1. Enable DoS Prevention
Open the DoS Prevention Policy tab.
  1. Enable DoS Prevention.
  2. Click Add to create a new policy.
  3. Configure the following settings:
SettingValue
NameDOS_PREVENTION_POLICY
FromWAN
Anomaly ProfileDOS_PREVENTION_PROFILE
StatusActive
Click Apply to save the policy.
Note: Applying the policy to the WAN interface ensures that Internet-originated reconnaissance traffic is inspected before reaching the firewall.
Step 2. Create a DoS Prevention Profile
Open the Profile tab and click Add.
Configure a descriptive profile name, for example:
This profile contains multiple detection engines, including Scan Detection, Flood Detection, and Protocol Anomaly Detection.
Step 3. Configure Scan Detection
Under Scan Detection, configure the following settings:
SettingRecommended Value
SensitivityMedium
Block Period5 seconds
Enable the following detection rules:
  • TCP Port Scan
  • UDP Port Scan
  • TCP Sweep
  • UDP Sweep
  • ICMP Sweep
  • IP Protocol Scan
  • IP Protocol Sweep
For each enabled rule:
  • Log: Enable
  • Action: Block
These settings allow the firewall to automatically detect reconnaissance activity and temporarily blacklist the scanning host.
Step 4. Configure Flood Detection
The Flood Detection engine protects the firewall from excessive volumes of traffic that may indicate a Denial-of-Service (DoS) attack. Each rule monitors a specific protocol and can automatically block hosts that exceed the configured threshold.
For this example, enable the following protection rules:
DetectionRecommended SettingReason
ICMP FloodEnableProtects against excessive ICMP traffic, such as ping flood attacks.
TCP FloodEnableProtects against high-rate TCP connection attempts that could exhaust firewall resources.
IP FloodEnableDetects abnormal IP packet flooding and provides additional protection against generic DoS attacks.
UDP FloodLeave DisabledUDP-based applications may generate bursts of legitimate traffic that could trigger false positives in some environments. Enable this rule only if your network has been evaluated and UDP-intensive services are not affected.
Block Period30–60 seconds
Threshold1000 (default)
ActionBlock
LogEnable
Note: Detection thresholds may need to be adjusted depending on your network environment. Enabling flood protection with overly aggressive settings can cause legitimate high-volume traffic to be temporarily blocked.
Step 5. Configure Protocol Anomaly Detection
The Protocol Anomaly Detection engine identifies malformed packets and protocol violations that may be used to bypass security controls or exploit vulnerabilities.
For this configuration, enable the following protection:
DetectionRecommended Reason
IP LAND AttackEnableDetects packets with identical source and destination IP addresses. This is a well-known attack with virtually no risk of false positives.
Leave the following protections disabled unless they are specifically required by your environment:
DetectionWhy it is disabled by default
ICMP Smurf AttackModern networks rarely encounter this attack, while some ICMP-based diagnostic traffic may be affected in specific environments.
UDP Smurf AttackSimilar to ICMP Smurf attacks, this protection is rarely required and may interfere with specialized UDP-based applications.
IP FragmentSome legitimate applications, VPN tunnels, or networks with lower MTU values rely on fragmented IP packets. Enabling this protection without prior testing may interrupt normal traffic.
Important: Security features that inspect protocol anomalies may occasionally identify legitimate traffic as malicious. Before enabling additional anomaly detection rules in a production environment, validate them in a test environment or monitor the logs to ensure that critical services are not affected.
Test the Result
Using the port scan tool Nmap or hping3 to scan the wan interface. For example, using Nmap security scanner for testing the result: Open the Nmap GUI, set the Target to be the WAN IP of USG Flex H (10.214.48.19 in this example) and set Profile to be Intense Scan and click Scan.
Navigate to Log & Report > Log / Events, you will see log of blocked messages.
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
