Nebula - Access Point AP Log Messages
Sometime's you will see some log entry's that are not that obvious to understand in NCC. For example, STA Logout, STA Timeout, STA Leave, Fast Roaming, Intra Roaming, iwpriv(kickmac), Hostapd3, prev-Auth Failed.
Normal AP log messages
  • Station: AA:BB:CC:DD:EE:FF has disassoc by STA Logout on [...]
The client left the WiFi either by getting to far away from the WiFi, or by disconnecting manually.
  • Station: AA:BB:CC:DD:EE:FF has disassoc by STA Timeout on [...]
AP didn't receive any traffic from that client for a period of time and kicked out the idle station.
  • Station: AA:BB:CC:DD:EE:FF has disassoc by STA Leave(L2UPFrame)
Client has left an access point after client is roaming to another access point
  • STA Fast Roaming MAC: AA:BB:CC:DD:EE:FF
Access point is using 802.11r (fast roaming) to get the client to roam without re-authentication
  • Station: AA:BB:CC:DD:EE:FF has deauth by Intra Roaming [...]
  • Station: AA:BB:CC:DD:EE:FF has associated on [...]
The client has roamed from the radio to another because the AP compared the signal quality and therefore changed the radio (e.g. from 5GHz to 2,4GHz).
Abnormal log messages
  • Station: AA:BB:CC:DD:EE:FF has disassoc by iwpriv(kickmac) [...]
Related to the feature of fast roaming, which can cause some issues. Please try to turn 802.11r off to see if it gets better
  • Station: xx:xx:xx:xx:xx:xx has blocked by Hostapd3 and has blocked by prev-Auth Failed
The log 'Hostapd3 +  prev-Auth Failed' means the WPA2 authentication is not successful. It might be caused by an incorrect password or packet loss during the authentication process. Please check the key in the password or if there's any high retry-rate information in the logs.
  • PN check failed
PN check failed event log stands for environment interference issue.  This mostly when you are using Smart Mesh.  Frequently followed by logs like the one's below
  • Repeater AP disconnected caused by Beacon Miss
  • Repeater uplink disconnected
This is a sign that interference is affecting the channels who are selected by the radio. To recover from this situation, you could try:
  1. Manually change to other channel or use DCS to choose the channel that has least interference.
Monitor for some days, if the situation is not getting better then:
  1. Change the channel width from 80MHz to lower(40 or 20MHz).
Articles in this section
Was this article helpful?
0 out of 2 found this helpful
Share
