FAQ Switch
Welcome to the Switch FAQ section of Zyxel's technical portal. Network switches are the backbone of any robust network infrastructure, enabling efficient data transfer and connectivity across your devices. This FAQ article addresses frequently asked questions about Zyxel switches, covering everything from setup and configuration to advanced features and troubleshooting. We aim to assist you in maximizing the performance and reliability of your network.
mceclip0.png Frequently Asked Questions
Critical Updates
Stay current with key security updates.
SAVE configuration!
VLAN (Virtual Local Area Network):
Everything about VLAN, here you will find information on setting up the basic VLAN and other VLAN setting options for our Zyxel devices. We have compiled this information for you to show the best possible setup. We will also give you a deeper insight into our VLAN design.
Voice VLAN
IP phones are commonly used in office environments, so giving voice traffic a higher priority is important when designing a network. In a common scenario of the installation, the IP phone is connected to a switch while linking the PC or laptop on the other end, bridging both devices. In this case, Voice VLAN is an important feature. Please have a look here:
Advanced VLAN
Based on 802.1q the Switch will discard unknown VLAN Frames. To pass through VLANs and only to configure easy  you can use VLAN Trunking:
VLAN, we cannot block clients in the same VLAN communicate with each other, take a look handle this:
If you want to learn / know more about our VLAN design, please have a look here:
Port Security
You will limit the number of connected devices. Please check:
Optimize Network / Network Security Options
Stacking / HA
Stacking is a must-have feature in managed switches for redundancy and HA. Find out how it works!
POE (Power over Ethernet Cable)
This feature can help you if you don´t have any power connector available, POE can help to start cameras, AP and more.
Overview Guides for Troubleshooting
Find out, how you can debug your switch!
 For more information browse through our article section: Click to start!
Articles in this section
Was this article helpful?
1 out of 10 found this helpful
Share
