How to Find Zyxel Accessories and Replacements
If you’ve lost an accessory or need to replace a component, you may be able to find the right spare parts and accessories — such as mounting kits for switches, firewalls, access points, antennas, cable glands, POE injectors, SFP Module and more — in our official Zyxel Online Store.
If the item you're looking for is not listed in the store, this means it is currently unavailable, and it is very likely that it will not be restocked.
https://store.zyxel.com/switching
https://store.zyxel.com/wireless-lan
What to Do If the Accessory Is Not Available?
Here are a few tips to help you find a suitable alternative when an original spare part is not offered:
  • Universal Rack Mounting Kits (Switches and Firewalls)
This article describes the dimensions of all ports for the H series switches and firewalls
Zyxel Rack Mount Guide: 19" Installation Support for Switches and H Series Firewalls
If the official rack mount kit for your switch or firewall is not available in our store, you can use a Universal Adjustable 19-Inch Rack Ear Kit.
Just make sure it is mechanically compatible with your Zyxel device (dimensions, screw positions, etc.).
  • Metric Cable Glands (for NR7101 or FWA710)
Some 5G routers — such as the NR7101 or FWA710 — use metric cable glands. Below you’ll find the original part specification, which can help you search for a suitable equivalent from third-party suppliers.
  • AVC MGM25/25 M25x1.5
  • AVC MG25AS M25x1.5
Pole mounting kit (NR7101 or FWA710)
If the original mounting bracket is unavailable for any reason, you may use any compatible alternative. The mounting hole pattern is 70×70 mm.
Articles in this section
Was this article helpful?
0 out of 2 found this helpful
Share
