Zyxel Network-Attached Storage NAS - Verified Hard Disk List for NAS Series
In this article, we will explain which disks are compatible with Zyxel NAS, whether you can transfer disks from one NAS model to another without data loss, the maximum size of internal and external disks for Zyxel NAS, and why the volume displayed in the web interface may be smaller than the actual disk size.
End-of-Life Product Notice We regret to inform you that the product "DEVICE NAME/MODEL" has reached the end of its useful life. As a result, technical support for this device may be limited. Please be aware that any manipulation or use of a device that is already end-of-life is entirely at your own risk.
End of Life (EOL/EoL) / End of Support (EOS/EoS)
Zyxel NAS shows a lower value than the manufacturer
The hard drive capacity appears smaller than claimed due to different definitions of storage units. File systems use binary units, while HDD manufacturers use decimal units.
Example: In a 10 TB HDD, one decimal terabyte equals 0.909 binary terabytes. Thus, 10 TB × 0.909 = 9.10 TB, which is the capacity indicated by the NAS system.
Replacing disks in Zyxel NAS without formatting
If you bought a new NAS and want to just plug in the old hard drives into the new one, you need to be very careful. The Zyxel NAS series uses software RAID to manage the files. We recommend plugging in hard drives only into the exact same model (e.g., NAS542 to NAS542). Moving from NAS542 to NAS326 will not work!
Furthermore, the NAS may see the RAID as degraded, so you will need to repair it. All shares that were available on the old NAS will either be disabled or simply not available.
We always recommend creating a backup of the files on an external hard drive before attempting any transfers.
Maximum External HDD Volume Size
The maximum size for an external disk is 8TB in NAS520, NAS540, and NAS542.
List of Compatible Disks
Most 3.5” SATA hard drives are compatible with our NAS series. The following drives have been tested and verified by Zyxel.
(Final Update: 2020.01.13)
Brand Model Name Capacity Interface
Seagate ST3500413AS 500GB SATA 3 Gb/s
ST3500514NS 500GB SATA 3 Gb/s
ZA960NM10001 960GB SATA 6 Gb/s
ST31000524NS 1TB SATA 3 Gb/s
ST31000524AS 1TB SATA 6 Gb/s
ST1000VN000 (NAS) 1TB SATA 6 Gb/s
ST1000VM002 (Video) 1TB SATA 6 Gb/s
ST1000VN002 1TB SATA 6 Gb/s
ST1500DL003 1.5TB SATA 6 Gb/s
ZA1920NM10001 1.92TB SATA 6 Gb/s
ST32000644NS 2TB SATA 3 Gb/s
ST32000641AS 2TB SATA 6 Gb/s
ST2000DL003 2TB SATA 6 Gb/s
ST2000DM001 2TB SATA 6 Gb/s
ST2000VN000 (NAS) 2TB SATA 6 Gb/s
ST2000VM003 (Video) 2TB SATA 6 Gb/s
ST2000VN004 2TB SATA 6 Gb/s
ST33000651AS 3TB SATA 6 Gb/s
ST3000DM001 3TB SATA 6 Gb/s
ST3000NC000 3TB SATA 6 Gb/s
ST3000VN000 (NAS) 3TB SATA 6 Gb/s
ST3000VM002 (Video) 3TB SATA 6 Gb/s
ST3000VN007 3TB SATA 6 Gb/s
ST4000DM000 4TB SATA 6 Gb/s
ST4000VN000 (NAS) 4TB SATA 6 Gb/s
ST4000VM000 (Video) 4TB SATA 6 Gb/s
ST4000VN008 4TB SATA 6 Gb/s
ST6000VN0033 6TB SATA 6 Gb/s
ST8000VN0002 (NAS) 8TB SATA 6 Gb/s
ST8000VN0022 8TB SATA 6 Gb/s
ST8000NE0004 8TB SATA 6 Gb/s
ST10000NE0004 10TB SATA 6 Gb/s
ST10000VN0004 10TB SATA 6 Gb/s
ST12000NE0007 12TB SATA 6 Gb/s
ST14000VN0008 14TB SATA 6 Gb/s
ST14000NE0008 14TB SATA 6 Gb/s
ST16000VN001 16TB SATA 6 Gb/s
ST16000NE000 16TB SATA 6 Gb/s
Western Digital WD5001AALS 500GB SATA 3 Gb/s
WD5002AALX 500GB SATA 6 Gb/s
WD5003ABYX 500GB SATA 3 Gb/s
WD1003FBYX 1TB SATA 3 Gb/s
WD10EFRX (RED) 1TB SATA 6 Gb/s
WD10EZEX 1TB SATA 6 Gb/s
WD10EURX 1TB SATA 6 Gb/s
WD10EALX 1TB SATA 6 Gb/s
WD1002FAEX 1TB SATA 6 Gb/s
WD1001FALS 1TB SATA 3 Gb/s
WD15EURS 1.5TB SATA 3 Gb/s
WD2000FYYZ 2TB SATA 6 Gb/s
WD20EFRX (RED) 2TB SATA 6 Gb/s
WD2002FAEX 2TB SATA 6 Gb/s
WD20EURS 2TB SATA 3 Gb/s
WD2002FYPS 2TB SATA 3 Gb/s
WD20EARX 2TB SATA 6 Gb/s
WD30EFRX (RED) 3TB SATA 6 Gb/s
WD30EZRS 3TB SATA 3 Gb/s
WD30EZRX 3TB SATA 3 Gb/s
WD4000FYYZ 4TB SATA 6 Gb/s
WD40EFRX (RED) 4TB SATA 6 Gb/s
WD40EZRX 4TB SATA 6 Gb/s
WD50EFRX(RED) 5TB SATA 6 Gb/s
WD60EFRX(RED) 6TB SATA 6 Gb/s
WD80EFZX 8TB SATA 6 Gb/s
WD120EFAX 12 TB SATA 6 Gb/s
Hitachi HDS721050CLA362 500GB SATA 3 Gb/s
HDS721010CLA332 1TB SATA 3 Gb/s
HDS722020ALA330 2TB SATA 3 Gb/s
HDS723020BLA642 2TB SATA 6 Gb/s
HDS5C3020ALA632 2TB SATA 6 Gb/s
HDS5C3030ALA630 3TB SATA 6 Gb/s
HDS723030ALA640 3TB SATA 6 Gb/s
HDS724040ALE640 4TB SATA 6 Gb/s
Toshiba MD03ACA100V 1TB SATA 6 Gb/s
MD03ACA200V 2TB SATA 6 Gb/s
MD03ACA300V 3TB SATA 6 Gb/s
MD03ACA400V 4TB SATA 6 Gb/s
Just a heads-up: Zyxel NAS devices have reached the end of their support period. We understand this might be inconvenient, so to help you out, please visit our forum or explore the NAS section in our knowledge base for all the details. You can also find a list of outdated devices and their support timelines at the link below.
Thanks so much for your understanding and patience!
Articles in this section
Was this article helpful?
8 out of 18 found this helpful
Share
