Zyxel Network-Attached Storage NAS - RESET button on Zyxel NAS Devices
Resetting a Zyxel NAS device is essential for troubleshooting and maintenance. This guide covers the procedures for resetting various Zyxel NAS models, ensuring you can restore default settings without losing data. Regular backups of your configuration are recommended for optimal data integrity.
End-of-Life Product Notice: We regret to inform you that the product "Zyxel NAS Devices" has reached the end of its useful life. As a result, technical support for this device may be limited. Please be aware that any manipulation or use of a device that is already end-of-life is entirely at your own risk. You can find a list of obsolete devices, including their retirement and end-of-support dates, at the link below. This page also provides the latest updated version for your device: End of Life
First RESET:
  • Action: Press the RESET button until you hear one beep (after about two seconds), then release it. You will hear one more beep after you release the button.
  • Result: This resets the NAS’s IP address and admin password to the default values (default password: "1234").
Second RESET:
  • Action: Press the RESET button until you hear two beeps. After the second beep, continue pressing the button for around five more seconds, then release it. You will hear three quick beeps after you release the button.
  • Result: This resets the NAS to the factory default configuration. All settings you have configured on the NAS, including IP address, password, user accounts, groups, and so on, will be reset to the factory defaults.
Important Note:
  • The reset process does NOT affect HDD settings or the data stored on the NAS. However, it is always good practice to periodically back up your configuration file to your computer.
Recommendations:
  • Please regularly back up your NAS configuration files to prevent loss of important settings.
  • Please make sure you are familiar with the specific reset procedures for your NAS model by consulting the user manual or Zyxel support.
Articles in this section
Was this article helpful?
81 out of 120 found this helpful
Share
