Zyxel Network-Attached Storage NAS - Backup and Restore Zyxel NAS
This article explains how to back up your files on a Zyxel NAS using Windows backup methods and demonstrates how to recover these files. With numerous configuration options available on our NAS, setting up a backup job can seem overwhelming. This tutorial will quickly clear up any confusion and guide you through the process of setting up a reliable backup job!
End-of-Life Product Notice: We regret to inform you that the product "Zyxel NAS Devices" has reached the end of its useful life. As a result, technical support for this device may be limited. Please be aware that any manipulation or use of a device that is already end-of-life is entirely at your own risk. You can find a list of obsolete devices, including their retirement and end-of-support dates, at the link below. This page also provides the latest updated version for your device: End of Life
Create a backup job
  • Log in to the web interface of the destination NAS using the admin account.
  • Navigate to Control Panel > Privilege & Sharing > Shared Folders, then click the + button.
    - Enter a suitable name for the folder (e.g., "backup") and click "Next".
    - Check the "Read/Write" box to grant all users Read/Write privileges. Click "Next", then "Apply".
  • Log in to the web interface of the main NAS using the admin account.
  • Open "Backup Planner" and click the + button.
  • Enter a name and description for your backup job select the "Mirror" option, then click "Next".
  • Choose the source folder you want to back up and click "Next".
  • Select the "Remote" option, and enter the IP address of the destination NAS and the admin credentials. Click "Show Target Content" to verify. Ensure that the admin passwords are different for both locations.
  • Select the folder created in Step 1 and click "Next"
  • Configure the backup schedule as desired, then click "Next" and finally "Apply".
  • Start the backup.
  • Select the newly created backup job and click the "Play" button.
Back Files on a Zyxel NAS using Windows backup
To get started, you first need to set up where the Files shall be saved.
  • On Windows 10, navigate to
Settings > Backup > More Options > See advanced settings > Select drive >
  • Add network Share and point to the share on your NAS.
  • Select the created path and click on "OK".
  • To activate it, click on "Turn on".
The files will then start copying to the NAS.
Restore Files from the Zyxel NAS
To restore data from the NAS
  • Navigate to
Settings > Updates & Security > Backup > More Options > Restore files from a current backup
  • Click on the restore button located at the bottom of the window.
Just a heads-up: Zyxel NAS devices have reached the end of their support period. We understand this might be inconvenient, so to help you out, please visit our forum or explore the NAS section in our knowledge base for all the details. You can also find a list of outdated devices and their support timelines at the link below.
Thanks so much for your understanding and patience!
Articles in this section
Was this article helpful?
3 out of 7 found this helpful
Share
1 comment
  • great article , Also I would to add that I use the easy way to backup to NAS, I use the Gs Richcopy 360 tool which has all the needed features, also it's quick and simple
    (Edited )
