Zyxel Network-Attached Storage NAS - Configuration of Copy/Sync button
In this article, we will describe the usage of the copy/sync button of the NAS series. You can configure two modes. a copy-mode and a sync-mode
Copy mode
mceclip0.png Log in to the NAS and find the Backup Planer app
  • Go to the Copy/Sync settings
  • Specify a target folder on the NAS
  • Specify the USB source
  • Specify the direction (NAS > USB; USB > NAS)
  • Choose if you want to create a new folder for the copied files OR if you want to replace the files.
  • Choose if replaced files shall be backed up
  • Click on Apply.
    You now can press the Copy/Sync button shortly to start copying the files.
Sync mode
  • Go to Sync Settings
  • specify a target on the NAS
  • specify a USB drive to sync from/to
  • define the sync direction (NAS > USB, USB > NAS, NAS <> USB)
  • Choose if files should be backed up and if they where
  • Click on Apply.
    You now can press the Copy/Sync button until you hear a beep tone to start the sync process.
Just a heads-up: Zyxel NAS devices have reached the end of their support period. We understand this might be inconvenient, so to help you out, please visit our forum or explore the NAS section in our knowledge base for all the details. You can also find a list of outdated devices and their support timelines at the link below.
Thanks so much for your understanding and patience!
Articles in this section
Was this article helpful?
3 out of 17 found this helpful
Share
1 comment
  • Thanks!
    It seems to work very well! But where can I see the status of how far the process went, how much time it still will need and (most important) when it is done?
    -1
