Verify Active Directory Authentication USG FLEX ZLD & USG FLEX H uOS
Use these CLI commands to verify Active Directory (AD) binding and test user authentication on Zyxel firewalls. Covers legacy USG FLEX (ZLD) and USG FLEX H (uOS) models. For ZLD, use debug domain-auth to validate the AD profile; for uOS, use cmd aaa/cmd ldap-check to test AD and LDAP access.
USG FLEX (ZLD) — AD bind & user test
You can use the following commands to verify that:
debug domain-auth test profile-name [ad profile name] username [username] password [password]
Example
Check successful
Router> debug domain-auth test profile-name ad username test password 12345678
Using short domain name -- BE
Joined 'BGO-ZYXEL-NXC' to dns domain 'test.your-domain.com'
/usr/sbin/winbindd -s /var/zyxel//ZyXELad.conf
ntlm_auth --username=test --password=12345678
NT_STATUS_OK: Success (0x0)
/usr/bin/killwinbind ad
Check failed
Router> debug domain-auth test profile-name ZyXEL_AD username zt01806 password 12345678
The configure is not ok!
Which means you have to check the configuration on the firewall or windows server.
Articles in this section
Was this article helpful?
2 out of 3 found this helpful
Share
