Zyxel Network-Attached Storage NAS - How to activate HDD Sleep Mode
Activating the HDD Sleep Mode on your Zyxel NAS can extend the lifespan of your hard drives, save energy, and reduce noise. This guide will walk you through the steps to enable this feature, ensuring your NAS operates efficiently.
Access the NAS Web Interface
  • Open your web browser.
  • Type in the assigned IP address of your NAS. This is typically something like 192.168.1.100, but it can vary depending on your network configuration.
  • Log in with your credentials. The default username is admin and the default password is 1234 unless they have been changed.
Step-by-Step Guide
Navigate to the Control Panel
  • Once logged in, locate and click on the Control Panel.
    Go to Maintenance > Power
  • In the Control Panel, navigate to Maintenance.
Under Maintenance, select Power.
Configure HDD Sleep Mode
  • Within the Power settings, find the drop-down menu for HDD sleep mode settings.
  • Choose the desired time after which the HDDs should turn off. This time indicates how long the drives should be inactive before entering sleep mode.
Enable Sleeping HDD LED Blinking
  • To visually indicate when the HDDs are in sleep mode, tick the option Enable Sleeping HDD LED Blinking. This setting will cause the LEDs to blink, indicating that the HDDs are in sleep mode.
Additional Information
Benefits of HDD Sleep Mode
  • Energy Efficiency: By putting your HDDs to sleep when not in use, you can significantly reduce power consumption.
  • Prolonged HDD Life: Reducing the operational time of the hard drives can extend their lifespan.
  • Noise Reduction: HDD sleep mode can decrease the noise level of your NAS, making it more suitable for home environments.
Important Considerations
  • HDD Activity: The HDD will only enter Sleep Mode when they are not in use. Any ongoing data transfer or access will prevent the drives from sleeping.
  • Wake-up Time: There may be a slight delay when accessing the NAS if the drives are in sleep mode, as they need to spin up again.
Additional Resources
For more detailed discussions, troubleshooting tips, and updates related to your Zyxel NAS, you can visit the Zyxel Personal Cloud Storage Community. This community offers a wealth of information, including user experiences, expert advice, and technical support.
By following these steps and taking advantage of the resources available, you can ensure that your Zyxel NAS operates efficiently, saving energy and maintaining the health of your hard drives.
Articles in this section
Was this article helpful?
1 out of 9 found this helpful
Share
