Firewall - Configure an SSID WiFi on USG/USG FLEX/ATP/NXC and UAG-devices
This step by step guide shows how to create an SSID for different devices. This shows how to set up your WiFi on your stand-alone device via the AP profile menu. This article works for USG, USG FLEX, ATP, NXC and UAG devices.
Walkthrough Steps:
1. Open the Configuration > AP Profile > SSID
2. Click the "Add"-icon to create a new SSID-Profile
3. Set up SSID according to your demands
4. If security measurements are desired, open the "Security Profile" tab
5. Add a Security Profile and set it up to your likings
6. Go back to the SSID tab, edit the recently created SSID
7. Add the new Security Profile to the SSID
For more information, refer to the following video:
Articles in this section
Was this article helpful?
1 out of 7 found this helpful
Share
