Understanding Router Mode vs. Bridge Mode (IP Passthrough) on Zyxel FWA Series Devices
Zyxel FWA 5G routers such as FWA710, FWA510, and FWA505 support both Router Mode and Bridge Mode (IP Passthrough). This guide explains the key differences between the two modes, when to use each, and how to configure them properly. Whether you're setting up a simple home network or integrating with a business-grade router or firewall, understanding these modes ensures optimal performance, secure connectivity, and the flexibility to meet different networking needs.
What is Router Mode?
In Router Mode, the Zyxel FWA device acts as a full-fledged router:
  • It obtains a public IP address from your Internet Service Provider (ISP) via the cellular network.
  • It creates a private Local Area Network (LAN) and assigns IP addresses to connected devices using DHCP.
  • It performs Network Address Translation (NAT), firewall protection, and traffic management.
Advantages of Router Mode:
  • Simplified setup for home users.
  • Built-in security features like NAT and firewall.
  • No need for additional networking equipment.community.zyxel.com
2. What is Bridge Mode (IP Passthrough)?
Bridge Mode, also referred to as IP Passthrough, disables the routing functions of the Zyxel FWA device, allowing it to pass the public IP address directly to another device, such as a firewall or a more advanced router.
Key Characteristics:
  • The Zyxel device becomes transparent to the network.
  • The public IP address is assigned directly to the connected client device via the LAN interface.
  • Routing functions like NAT, DHCP, and firewall are disabled.
Advantages of Bridge Mode:
  • Ideal for business environments requiring advanced network configurations.
  • Eliminates double NAT issues, which can affect VPNs and VoIP services.
  • Allows the use of specialized external networking equipment.spdl.zyxel.com
Compatibility of Bridge Mode / IP Passthrough in Zyxel FWA Devices
Model Router Mode Bridge Mode / IP Passthrough Notes
FWA505 ✅ ✅ Supports IP Passthrough; availability may depend on firmware and ISP.
FWA510 ✅ ✅ Offers IP Passthrough; some users report limitations in full bridge functionality.
FWA710 ✅ ✅ Fully supports IP Passthrough as per official documentation.
How to Enable IP Passthrough on Zyxel FWA Devices
To configure IP Passthrough, follow these steps:
  1. Access the web interface of your Zyxel device.
  2. Navigate to:manualsnet.com
    Network Setting > Broadband > Cellular > IP Passthrough
  3. Enable IP Passthrough.
  4. Choose the mode:
    • Passthrough Mode: Enable
    • Passthrough Type: DHCP (default) or Manual, depending on your setup.
  5. Select the interface (e.g., LAN1) to which the public IP will be assigned.
  6. Apply the changes and reboot the device.support.zyxel.eu
Note: Some ISPs may use Carrier-Grade NAT (CGNAT), which can prevent the assignment of a public IP address to your device.
Comparison Table: Router Mode vs. Bridge Mode (IP Passthrough)
Feature Router Mode Bridge Mode / IP Passthrough
Public IP Assignment To Zyxel device To connected client device
NAT Enabled Disabled
DHCP Server Enabled Disabled
Firewall Enabled Disabled
Network Management Handled by Zyxel device Handled by external router
Suitable for Home Use ✅ ⚠ Requires external router
Suitable for Business Use ⚠ Limited ✅ Full control with external equipment
When to Use Each Mode?
Use Router Mode if:
  • You do not have an external router or firewall.
  • You prefer a straightforward, all-in-one networking solution.
  • You require basic network security features without complex configurations.
Use Bridge Mode / IP Passthrough if:
  • You have advanced networking equipment, such as a dedicated firewall or router.
  • You need to assign the public IP address directly to another device.
  • You want to avoid double NAT issues, which can interfere with certain applications.
MGMT Services
There will be two Mgmt Services Tabs on the Device GUI.
"MGMT Services" is being used if the device is in "WAN Routing Mode", and "MGMT Services for IP Passthrough" will be used if the device is in "IPPT Mode".
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
