Zyxel Nebula 5G Router FWA Series - Comparing Zyxel 5G Routers: FWA505 vs. FWA510 vs. FWA710
Zyxel’s FWA series offers flexible 5G connectivity solutions for various environments, from small offices to remote outdoor deployments. This article compares the three key models, FWA505, FWA510, and FWA710, to help you choose the right device for your needs.
Nebula FWA505 Nebula FWA510 Nebula FWA710
Disclaimer: The information in this article is based on Zyxel’s official product documentation. However, features and specifications are subject to change due to firmware updates or product revisions. For the most accurate and up-to-date details, always refer to the official datasheets and product pages:
Comparison Table
Feature FWA505 (Indoor) FWA510 (Indoor) FWA710 (Outdoor)
Deployment Type Indoor Indoor Outdoor
5G Bands Sub-6 GHz, NSA/SA Sub-6 GHz, NSA/SA Sub-6 GHz, NSA/SA
WiFi Standard WiFi 6 (AX1800) WiFi 6 (AX3600) N/A (Ethernet only; use external AP)
Ethernet Ports 2 x 1GbE 2 x 2.5GbE 1 x 2.5GbE (PoE)
Antenna Design 4x internal 4x external (TS-9 ports) 4x high-gain directional antennas
Management Nebula Cloud / Local GUI Nebula Cloud / Local GUI Nebula Cloud / Local GUI
Ideal Use Home office, small businesses SMEs, performance-critical offices Remote/rural outdoor sites
IP Rating Not rated Not rated IP68 (weatherproof)
Model Highlights
FWA505 – Compact 5G for Indoors Router
An easy-to-deploy 5G router with internal antennas and AX1800 WiFi 6, best suited for homes or small offices needing basic high-speed failover or primary connectivity.
FWA505 Product Page
FWA510 – High-Performance Indoor Router
Offers stronger wireless performance (AX3600), 2.5GbE ports, and external antenna support. Perfect for offices requiring higher throughput or signal optimization.
FWA510 Product Page
FWA710 – Rugged Outdoor 5G Router
IP68-rated device with built-in high-gain directional antennas and PoE support. Designed for harsh environments and fixed wireless access in rural or challenging locations.
FWA710 Product Page
Conclusion
  • FWA505 is ideal for simple indoor deployments where ease of use and affordability matter.
  • FWA510 provides higher performance and flexibility for more demanding indoor networks.
  • FWA710 is purpose-built for outdoor, rural, or fixed wireless access deployments requiring ruggedness and long-range coverage.
All models are fully compatible with Zyxel's Nebula cloud platform, providing centralized management and monitoring.
Articles in this section
Was this article helpful?
2 out of 4 found this helpful
Share
