Lost or Forgotten Your Router Password? Here's How to Recover It!
If you have forgotten your device password, find that it no longer works, or are unsure where to locate the default password, this guide provides essential information. You will learn how to find the default password for your device or restore and reset it if needed.
Check for the Default Password
Many devices have a default password printed on a sticker or listed in the user manual. Check your device’s label or documentation for login details.
2. Perform a Factory Reset
If the password was changed and is now forgotten, a factory reset can restore the device to its default settings. After resetting, use the standard password in the manual or on the device itself.
Zyxel 5G Devices [NR/FWA] - Basic Troubleshooting 5G devicec NR and FWA series
3. Contact Your Internet Provider
A factory reset might not allow access for devices issued by your internet provider. In this case, contact your provider for assistance with login credentials.
4. Reach Out to Technical Support
If none of the above methods work, open a support ticket with the manufacturer’s technical support team for further assistance.
Articles in this section
Was this article helpful?
7 out of 46 found this helpful
Share
