How to Find Your Router's IP Address on Any Device ?
Looking for your router's or modem IP address? This guide will show you the easiest ways to find it, whether you're using Windows, Mac, Android, or iPhone. Learn how to access your router's settings. Get step-by-step instructions for any device and quickly determine your IP address.
As a rule, you can find this information on the sticker of your device, which is often contained there and you can also refer to the user manual. The user manual can be found in our  Download Library.
For an example of what it looks like on the sticker and where it can be found in the user manual:
Router label with IP address
Router user guide login details
Valuable articles that may help you:
You can also check the router's IP address by connecting your computer to its LAN port if the router assigns an IP address via DHCP.
Windows
   Press Win + R, type cmd, and hit Enter.
   Type ipconfig and press Enter.
   Look for Default Gateway—this is your router’s IP.
Mac
   Open System Settings > Network.
   Select your connection (Wi-Fi or Ethernet).
   Find Router—this is your IP.
Android & iPhone
   Go to Wi-Fi settings.
   Tap your connected network.
   Find Router or Gateway IP.
Now you can access your router settings!
Articles in this section
Was this article helpful?
3 out of 7 found this helpful
Share
