SecuExtender VPN - Perpetual License End of Life EoL / Phase Out Announcement
Zyxel phased out the SecuExtender perpetual license on USG / USG FLEX / ATP / VPN series. Subscription-based licenses will replace the perpetual license (EoL) and are available now.
Note: As of October 3, 2023, SecuExtender Perpetual Licenses can no longer be activated or reactivated. Zyxel Support is no longer able to process activation or reactivation requests.
Affected devices:
  • Legacy USG / Zywall Series
  • USG FLEX Series
  • ATP Series
Service License Activation Last Date Last activation date Last Date of Support from Zyxel Notes
Perpetual SecuExtender License - SECUEXTENDER-ZZ0106F 31 March 2023 1 April 2023 2 October 2023 Migration Path: SECUEXTENDER-ZZ1Y01F
Key Notes:
  • It's no longer possible to buy or activate the Perpetual SecuExtender licenses
  • If they are activated and is already used, they will continue to work
  • If you want to use SecuExtender, you need to use the subscription-based Client with the subscription-based license
The following licenses are now announced End of Life
SECUEXTENDER-ZZ0201F SecuExtender, IPSec VPN WINDOWS Client 1 License
SECUEXTENDER-ZZ0202F SecuExtender, IPSec VPN WINDOWS Client 5 Licenses
SECUEXTENDER-ZZ0203F SecuExtender, IPSec VPN WINDOWS Client 10 Licenses
SECUEXTENDER-ZZ0204F SecuExtender, IPSec VPN WINDOWS Client 50 Licenses
The following licenses (Subscription-based) are replacing the legacy licenses (lifetime)
SECUEXTENDER-ZZ1Y01F SecuExtender; Zero Trust, IPSec VPN Client Subscription Service for Windows/macOS, 1-user; 1YR
SECUEXTENDER-ZZ3Y01F SecuExtender; Zero Trust, IPSec VPN Client Subscription Service for Windows/macOS, 1-user; 3YR
SECUEXTENDER-ZZ1Y05F SecuExtender; Zero Trust, IPSec VPN Client Subscription Service for Windows/macOS, 5-user; 1YR
SECUEXTENDER-ZZ3Y05F SecuExtender; Zero Trust, IPSec VPN Client Subscription Service for Windows/macOS, 5-user; 3YR
SECUEXTENDER-ZZ1Y10F SecuExtender; Zero Trust, IPSec VPN Client Subscription Service for Windows/macOS, 10-user; 1YR
SECUEXTENDER-ZZ3Y10F SecuExtender; Zero Trust, IPSec VPN Client Subscription Service for Windows/macOS, 10-user; 3YR
SECUEXTENDER-ZZ1Y50F SecuExtender; Zero Trust, IPSec VPN Client Subscription Service for Windows/macOS, 50-user; 1YR
SECUEXTENDER-ZZ3Y50F SecuExtender; Zero Trust, IPSec VPN Client Subscription Service for Windows/macOS, 50-user; 3YR
FAQ
1. Can I use Perpetual Config Export and Import into the new Subscription-based client?
If you import TGB files from Subscription-based to Perpetual-based VPN client, it may cause unexpected issues because the configuration sets are different.
We recommend that users obtain a new TGB provision file again from the firewall.
2. A Windows computer crashed, do you still support license renew for activation of existing ones?
We support re-activation of the perpetual license until 2 October 2023 after that, we at the Support organization cannot activate the license anymore and will not support it.
3. Can we can contact support after April 1st to convert license into Subscription one?
There is a license key swap program in place, where our customer is eligible to swap their unregistered lifetime key to a 3 year subscription key.
Here are some articles on how to configure your devices to fit the new Best Practices
SecuExtender - Reinstall the Zyxel IPSec VPN Client
VPN - Configure IKEv2 VPN with Certificate using SecuExtender IPSec VPN Client
IPSec VPN Client Setup with Nebula Security Gateway ( Client-To-Site; C2S )
VPN - Download SecuExtender for MacOS
Articles in this section
Was this article helpful?
0 out of 1 found this helpful
Share
