FAQFirewall High Availability HA Pro – Questions & Answers for Zyxel ZLD Firewalls
In today’s always-on business environment, network reliability is critical. Zyxel’s Device HA Pro, available on Zyxel ZLD firewalls, ensures minimal downtime and seamless recovery. It provides a robust and easy-to-manage high availability (HA) solution with built-in synchronisation and monitoring features — explicitly designed for ZLD-based devices (not to be confused with HA options on Zyxel Firewall H-Series).
Firewall High Availability [HA Pro] - Configure Device HA Pro
Firewall High Availability [HA Pro] - Device HA Pro redeploy
Firewall High Availability [HA Pro] - How to replace a defective device in HA Pro
Firewall High Availability [HA Pro] - Recovery of your HA Scenario without unbinding
Firewall High Availability [HA Pro] - Firmware Update in Device HA Mode
Streamlined Deployment with a Dedicated Link
Traditional active/active HA setups often required complex routing knowledge and extra system resources. Device HA Pro simplifies deployment with an active/passive architecture.
  • The active firewall handles all production traffic.
  • The passive firewall stays in standby mode, continuously synchronizing configuration, session tables, and routing information through a dedicated HA link.
  • This approach minimizes setup complexity and guarantees that the backup unit is always ready to take over.
Instant Failover Response
Device HA Pro is engineered for rapid, near-invisible failover.
  • In case of hardware failure, link loss, or heartbeat signal interruption, the passive unit automatically takes control.
  • The switchover typically completes within five seconds, preserving active sessions and minimizing user disruption.
  • Failover occurs only when necessary, ensuring stable continuity without unnecessary role changes.
With Device HA Pro, organizations gain a resilient, automated, and easily managed HA setup for uninterrupted operations.
License Synchronization Best Practices
  • In the Device HA Pro settings, make sure to configure the primary device’s serial number under “Serial number of the licensed device for license synchronization”.
  • This ensures license transfer during failover.
  • After synchronization, the passive device will display only a trial license, but inherits the full license set when it becomes active.
  • License status can be verified anytime via myZyxel.com.
Frequently asked questions
Q: Do I need two licenses (e.g., UTM licenses) for Device HA Pro?
A: No. Only one license is required. The active device’s licenses are automatically inherited by the passive unit during failover.
Q: Is HA Pro supported in Nebula mode on USG FLEX (ZLD) or ATP (ZLD) series devices?
A: No, HA Pro is not supported in Nebula-managed mode on USG FLEX or ATP devices. However, you can still use HA Pro by switching the device to standalone (on-premise) mode.
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
