VPN - SecuExtender IPSec IKEv1 / IKEv2 using 2FA via Email server
In this article, we will show how to configure the 2FA (Two Factor Authentication) with an IPSec VPN on USG FLEX / ATP / VPN Series. This article will further show how to configure the firewall (VPN Gateway, VPN connection.
Table of Content
1) Configure 2FA on the Firewall
1.1 Create a VPN Gateway profile
1.2 Create a VPN Connection profile
1.3 Create a new user for X-Auth
1.4 Add new users to Two-factor Authentication
1.5 Setup a Mail server
1.6 Create a Security Policy (Firewall rule)
1.7 Create an IKEv1 Gateway in IPSec VPN Client
1.8 Create a VPN Connection
2) Check the results
VPN => IPSec VPN => VPN Gateway
Chose Aggressive negotiation mode
VPN => IPSec VPN => VPN Connection
Object => User/Group
Object => Auth. Method => Two-factor Authentication
Tick on IPsec VPN Access, select user, and tick on the corresponding delivery method (Email from my example)
System => Notification
Create allowing security policy rule from wan to Zywall for 8008 port, make sure they're also allowed protocols IKE, NAT-T, and ESP in the same direction:
Security Policy => Policy Control
Enable X-auth:
Also, in the protocol section, tick on both options - Mode Config and Aggressive Mode.
Identity is optional.
VPN Client address must be in read mode.
The Remote LAN address adds an address set in the Local Policy on the VPN server.
In the end the log should look like this:
Articles in this section
Was this article helpful?
1 out of 1 found this helpful
Share
