Zyxel Circle License platform - The New Zyxel License Platform Overview
Zyxel Circle simplifies license and asset management for partners, focusing on consolidating renewals in one platform. It enhances customer engagement by allowing partners to manage all licenses centrally and organize devices by organizations and sites. The article covers accessing Zyxel Circle, portal functionality including device import from MyZyxel, and detailed license management for supported security products. This article covers gaining access to Zyxel Circle, understanding its portal functionality, importing existing devices from MyZyxel, and effectively managing licenses.
Registration request
To apply for Zyxel Circle, please use the following link: https://circle.zyxel.com/. There you may click on the "Apply now" button. A business account is required to apply.
On the next page, you will be prompted to confirm your business information:
After submitting the form, your application will be reviewed. Once your account is ready, you will be notified via e-mail and you will be able to access the Zyxel Circle portal.
Portal Overview
After logging in to Circle, you will be welcomed with the dashboard that will provide you with an overview of licenses that will expire soon and other useful statistics.
The "My Devices" page allows you to view and edit the entire hierarchy of your sites, organizations and groups. The search field provides you with an option to quickly find the desired device within the current view. You can search for the model, device name or serial number. You may also filter the devices by their current license status.
Creating organizations and groups
To organize the devices of your customers, you may group sites in organizations and organizations to groups.
Create organizations
Select multiple sites and then right-click to create a new organization or drag the sites into an existing organization:
Create groups
Select multiple organizations and then right-click to create a new group or drag organizations into an existing group:
Import devices from MyZyxel
In the "My Devices" menu, you can select the desired site where you wish to import your devices and click on the "Add Device" button.
In the next menu, you will be prompted if you wish to register new devices or import devices from a MyZyxel account. This can be either your account or an account from your customer - in that case, the customer needs to approve such action.
On the next page, you can select which devices you want to import to this site and confirm the dialogue.
Your device should now be part of your Circle site:
Please note that while Circle can import devices from MyZyxel portal, the database is independent of MyZyxel. If you have hardware you no longer wish to manage, you don't need to import it into Circle, also decommissioned hardware can be simply removed from Circle in the device's overview using the "Advanced Settings" button on the top of the screen.
License management
Upon opening the device information page on the "My Devices" page, you may check its current license status or extend the current license directly. To extend your license, enter the "Renewal & Purchase" tab and select the respective license that suits your needs.
You may also select multiple devices at the same time on the "My Devices" page for license renewal. Simply select all the devices you wish to get renewed and click the renew licenses button on the top menu.
You may also buy licenses directly in the "License Store" menu - there you can buy any license Zyxel is offering for any of our products. Easily. Conveniently. All in one place.
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
