Nebula Information - How long does it takes to see data updated on Nebula Control Center?
Why does it take time for a network client to appear on the client pages of the Nebula Control Center after connecting to the access point or wired devices?
Being a cloud solution, Nebula requires the supported devices to sync the data information to its servers, and in order to avoid high bandwidth utilization of your network or the increase of the device's CPU usage due to permanent connections; the Nebula solution implements a polling interval time to get the device data information. This varies in each product type as the following details:
  • Gateways need 3 minutes to sync and update to the Nebula control center
  • Switches need 5 minutes to sync and update to the Nebula control center
  • Access points need 3 minutes to sync and update to the Nebula control center
The polling process also differs for each device, meaning that the data information polled from AP-1 might not be at the same time for AP-2:
Please note that the first time the device is connected to Nebula, the data polling might take longer as the device is also being configured with your NCC site settings. NebulaFlex™ and NebulaFlex™ Pro supported devices will require a longer time since the devices are also getting converted from another mode to Cloud mode, experiencing reboots within the process.
Articles in this section
Was this article helpful?
3 out of 3 found this helpful
Share
